Question about Olympus FE-170 Digital Camera
Card error I have an Olympus C-170 camera, when I turn it on, 2 options are given: 1. power off and 2. format... when i choose format, it will erase all the pictures. All the other functions in the camera is not working... I havent formatted the card since i dont want to erase the pictures in it. When i take off the card and insert it to my card reader of my laptop, an error message appears that the card is not formatted. I have stored pictures that are very important to me. Please help.
    President:
  • 919 Answers
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering images.
Posted on Feb 12, 2009
SOURCE:
I need to set up the card on my Olympus C-5060 camera. When I choose the format button, it just beeps forever.
1. Power the camera off and remove and replace the card several times.
2. Recheck.
3. Put in another memory card and check.
If the recheck (2) does help, it may be dirty contacts.
If another memory card has the same issue, the camera needs repair.
Nov 27, 2011 | Olympus Camedia C-5060 Wide Zoom Digital...
When I turn on the camera the light remains red,
I there its not locked. Follow the step below & let me know.
1. Use a fully charged rechargeable battery & remove the memory card.
2. with out memory card if its working then the card is damaged or virus infected. So please format the card and fix it back. Then try to power on your camera with memory card. I hope your problem will solve them. If not then i suggest you contact with service center. Chances of Lens guide pin damaged/ processor may corrupt. Thanks & waiting for your feedback.
Apr 07, 2010 | Olympus FE-170 Digital Camera
Error code olympus c4040 zoom
At this point it sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card and it can be used again. Make sure you download all images prior to formatting as once the card is cleared all data is lost.
May 05, 2009 | Olympus Camedia C-3020 Zoom Digital Camera
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
Error message on olympus camera
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 20, 2009 | Olympus Stylus 710 Digital Camera
DELETING PHOTOS ON OLYMPUS C-420L
To format the card:
1 Pressing the Erase mode button and the Flash mode
button at the same time sets the screen to the YES/NO
display.
2 Press the OK button to start formatting (the Card error
indicator blinks). Press the Erase mode button to cancel
the mode.
3 When the card formatting is done, the Card error indicator
goes off.
To re-format the card intentionally:
Press the Erase mode button and the LCD monitor ON/OFF
button simultaneously, with the power OFF, to set to the Yes/No display and then press ok.
Apr 09, 2009 | Olympus Camedia C-820L Digital Camera
Olympus c150 camera put new memory card in getting message card set up format power off then mesage erasing all help please i have a C-170 camera, when I turn it on, 2 options are given power off and...
The problem is that the largest xD card that your camera can support is a 256mb card. The M or H 256mb cards are not compatible. The firmware in the camera cannot support memory storage of that type. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Feb 11, 2009 | Olympus FE-170 Digital Camera
Can't make any photo or preview
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Jan 04, 2009 | Olympus Camedia D-425 / C-170 Digital...
CAN'T EDIT OR MAKE ANY PICS
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Olympus FE-170 Digital Camera Logo
110 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
