Question about Kenmore Elite HE4 Electric Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
The dryer heats just fine, starts the cycle and then starts to think that the clothes are dry. Then it cuts the time down by half and quickly starts the cool down cycle. It is taking me 4-5 times longer to get things dry...and sometimes longer.
    President:
  • 1,902 Answers
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Posted on Feb 12, 2009
2 Suggested Answers
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Posted on Oct 05, 2008
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
Dryer is not heating.
you need to return it from the seller
Mar 27, 2012 | Dryers
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
Kenmore 120V portable dryer only gets lukewarm
Sometimes the venting in the dryer needs ton be cleaned out as it plugs up and the high limit thermostat makes it short cycle on the heat cycle.
Mar 20, 2010 | Kenmore 82722 Electric Portable Dryer
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
Amana Special Edition Electric Dryer Model ALE868QAW not drying
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
GE Dryer DDE7200SBLWW doesn't dry quickly
it sounds like it could be your vent turn dryer on go outside and feel your air coming out of vent if not a good air supply clean your venting system
Dec 13, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
337 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
