Internet ! hi there, i have a internet problem on my psp... when i try to access it it says check security settings can u plz tell me what they are spose to be on? google.com
    Guru:
  • 832 Answers
Hello there!! thanks for using Fixya.com!
You know what, I had the same problem couple of months ago. But I suggest that you should enter manually the network settings for the WLAN internet connection.
You have a pretty common configuration and there's good and bad news. The good news is that yes, you can definitely get your Sony PSP onto the Internet with the setup you have. The bad news is that I'm not exactly right when I say "with the setup you have" because you're going to need to buy what's called a wireless router to connect.
Basically, the setup you have works like this:
highspeed Internet connection from service provider (BT in your case) connects to highspeed modem connects via Ethernet cable to your computer.
While you can configure the wireless network with a password, since the Sony PSP claims to support the various secure wireless protocols, my experience is that it never connects properly. Instead, I suggest you leave it password-free, though it's not particularly secure. If you have good neighbors, you're probably safe...
Or you may just simply:
Wireless network connection Step1Turn on the “WLAN” switch on your PSP when you are in range of a wireless access point. Step2Select the “Network” option on the “Home” menu. Step3Select the “Internet Browser” option and then press “X.” Step4Use the Up and Down direction buttons to select the address bar. Step5Press the Circle button to display the onscreen keyboard. Step6Use the onscreen keyboard to enter a Web address. Step7Select the “Enter” key and then press button “X.” Step8Select a connection and then press “X” to display the Web page. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); good luck!
Posted on Feb 16, 2009
I have a new psp 3000. I can't get internet access. It finds the SSID, good reception=75%. WLAN on, but its saying "a connection error occurred. Connection point could not be established. Check...
Hi stagedoorste,
You may notice that sometimes connecting your PSP to your network seems like a hard thing to do. But if you're aware of the basic configuration you can say that it's not a complicated thing. If your experiencing hard time connecting to the internet please make sure to check on the error. Based on what you have mentioned it says that you need to check the security setting. You may try following the steps below for the basic configuration on how to connect your PSP to your router.
1. First step is to make sure to turn on your PSP as well as the wireless/WLAN switch. 2. Then Navigate to " Network Setting". 3. Select "Infrastructure Mode". 4. Now Select "New Connection" and Name this connection as you deem appropriate. 5. Navigate to "WLAN Settings" Select "Scan". 6. Your router should now be listed. 7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None" 8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA. 9. Then navigate to "Address Settings". Select "Easy" 10. Go to "Setting List". Verify that your settings are correct. 11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X. 12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection and using your PSP you can now browse the net.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Slim...
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp won't connect to the internet. it says, a commection error has occured. a connection to the access point could not be established. check the security settings for the network and try again.
First of all check if your wireless router requires (WEP KEY) to establish a connection then you will have to put same (WEP KEY) in PSP WLAN security setting and if your wireless router is set without (WEP KEY) then in PSP WLAN security setting it should be set to None. kindly refer to the following image.3782ff8.png
Oct 20, 2010 | Sony PlayStation Portable (PSP) Console
Set up Internet access on PSP
IF YOU HAVE THE WEP SUCURITY, YOU CAN FIND THE CODE UNDER OR BEHIBD THE WIRELESS ROUTER iT WOULD SAY "WEP KEY"AND THEN IT WOULD SHOW YOU THE CODE.
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
Im trying to get the internet on my psp but keep geting a dns error code 80410418 can u plz help
You have to know all the internet settings of the connection your are trying to use...
See if this connection are using some security Protocols...
try to folow all the Psp connection wizard and set all the configuration correctly....
Good Luck!
Dec 09, 2008 | Video Game Consoles & Games
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Psp security code
go to setting --- select system settings --- restore default settings---
the password then should be set to 0000 so u can change your parent game setting/internet things.
Mar 26, 2008 | Sony PlayStation Portable (PSP) Console
Internet !
you need your own internet connection
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
PSP internet problem ongoing
has it ever connected to the wireless router if not try changing the settings of sercurty wpa-psk
Sep 21, 2007 | Sony PlayStation Portable (PSP) Console
Psp internet problem
You need to enter the wep key, ONLY if you have wep enabled on the wireless connection.
Sep 15, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
