Question about HP PSC 2210 All-In-One InkJet Printer
Pictures I scan is always in sRGB but I need CMYK quality
The default setting I have - Windows Color system is sRGB IEC61966-2.1 - can be changed, I can see that.
There is a lot of other profiles to choose from!!
What is compatible, i.e. give the result, to CMYK???
The printer's office demand my scanned pictures to be in CMYK (=black!!)
Open the image in photoshop or Irfanview and convert it with the mode command to a cmyk file and save it.
Posted on Feb 14, 2009
How do I change the default color profile? I have calibrated my NC-10 with a Spyder3 and the new profile is shown together with the ''srgb color space profile''. The problem is that when i restart my NC-10...
Instructions Download an icc profile above, then (in windows XP), go to display properties > settings tab > advanced > color management > add
Select the downloaded icc profile, set as default. You now need to reboot windows -
Jan 16, 2010 | Samsung NC10-14G Notebook
When I print color, the page has a lot of extra toner.
Start with this
  1. Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  2. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
Next. This is on xerox.com downloads and drivers.
The updated sRGB Display and sRGB Vivid color tables for the WorkCentre will help with the following issues that have been found with the original factory color tables.
  • RGB images contain too much yellow.
  • RGB image red shades are too orange or too light.
  • RGB object blues are too dark or aqua.
  • CMYK objects use the sRGB Display color table when the Automatic TekColor correction is used. After the updated color tables have been downloaded to the WorkCentre, the CMYK objects will use the Commercial Press TekColor correction when Automatic is used as the TekColor correction.
    NOTE: The new color tables will only take affect when using the Enhanced or High Resolution / Photo print quality mode.
To update the RGB color tables:
  1. Click on the [Drivers & Downloads] link under the Product Resources menu on this window to download the updated color tables to a known location on the computer's hard drive. The color table update file is located under the Color Profiles section on the Drivers and Downloads page.
  2. After the file has been downloaded to the computer, send the file to the WorkCentre. See the Related Items below for additional information.
Jan 07, 2010 | Xerox WorkCentre M-24 Color Copier
Picture comes out like a color negative/x-ray
I solved this problem by going to "Printer Properties"...then "Color Mangement"...then "Advanced"...then I changed "viewing conditions profile" to:
system default (WCS profile for sRGB viewing conditions). Haven't had any color problem since.
Nov 15, 2009 | HP Photosmart D7360 All-In-One InkJet...
Why Recieve Bad quality for picture CMYK mode in umax 2100 XL?
What makes you think the scan is bad quality? How are you proofing it. Did you print in on a printing press or other CMYK device? The CMYK colorspace cannot be displayed on monitors without the program you are using converting it to RGB for display. Are you reading the actual CMYK values with the densitometer?
In my experience, with cheap scanners (under $75,000) it's best to scan to RGB and let Photoshop do the CMYK conversion. Just be sure to use the correct profile for your output intent.
Feb 05, 2009 | Umax BINUSCAN - PhotoPerfect CMYK & RGB...
Printing issues with Epson r285
hi! try this! 1. go to control panel, select the printer, then right click the model of your printer, select properties, then select printing preferences.    in printing preference, select effect, then check the box of vivid photos. If you check vivid photos it will add enhancement to your printout. But thats not it, 2. open your photoshop, find your color settings, set your RGB color to (sRGB IEC61996- 2.1) then you CMYK color to (U.S. Web Coated (SWOP) v2) then off all your Color-management Policies and don't mind anything. 3. After your Edit your photos from RGB, then convert it to CMYK, then try printing it.
Dec 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Canon Copier CLC 900 problems color management settings
you can buy manuals for little money from canon.com. Cheers Thomas
Nov 27, 2008 | Canon CLC-700 Copier
Old photos scan great into folder on Mac but appear black when transfered to IPhoto on m
hmm..well..that is a little weird..can you supply the operating system for your mac, and also the rev level of image capture?
Oct 28, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
HP PSC 2210 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
