Question about Echo Garden
REstringing the cutting line
Srm 210 Echo trimmer, Don't know to restring w/o buying the expensive new peice
#1 Taper
  • 1040 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
Dolfoff
  • 148 Answers
SOURCE: need to install new lever trigger lockout but
Navigate to your exact model using Echo's public website.
Click the "WEB-PLUS PARTSEARCH" link at the bottom right of their homepage.
Posted on Sep 26, 2009
  • 87 Answers
SOURCE: need to replace the trimmer head cutting line.
Did you try pushing down hard and turning @ the same time? that should do it.
Posted on Oct 05, 2009
SOURCE: Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Posted on Feb 06, 2011
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem...
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Oct 22, 2013 | Echo Zama Carb Kit For Shc210 For Rbk66b...
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
How to add line to an echo srm 210 weed trimmer
See pages 27 and 28 of the owners manual here:
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
This certainly explains it better than I can.
Oct 01, 2010 | Echo Garden
How do I change the cutting line on my SRM 210 ? I do not have a manual.
You may be able to download an owners manual here as your model is a very popular one and they may have it.
http://www.manualsonline.com/
Stringing the head info should be in the manual.
Aug 29, 2010 | Echo Garden
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Need to install new lever trigger lockout but can't figure out how to install spring on echo trimmer srm 210
Sep 17, 2009 | Echo Garden
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
How do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
May 03, 2009 | Garden
Garden Logo
230 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
