Question about Acer AOpen AW 230 Sound Card
No sound am not getting any sound from my computer
  • jannath_farh Feb 28, 2009
    by mistake i removed the mixer driver of my acer notebook. i expect for a solution for this problem. thank you.
  • Anonymous Apr 04, 2009
    i made format for my computer then i have no sound maybe because i do not have a cd definition for the computer
  • 744 Answers
Hi try checkin out this....if device manager shows its ok (right click my computer, left click properties, choose hardware tab then device manger - see whats listed under sound and audio devices , any red X's etc)if it looks ok in there - open all Your audio programs, real, win media and any others make sure none are on mute and up full volume lastly go into control panel souns and audio devices, on audio tab make sure You have Your sound card as default audio playback - - - where their any other hardwares that came with the game, i.e headsets, joypads etc that could have set themselves to the default audio devices?....
thank u rate me!!!
Posted on Feb 12, 2009
I am having trouble getting my sound to work on my computer, it says i have no sound card installed on my computer and i do not know how to get a sound card installed on my computer.... Please help!
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
or
you might have to get a portable usb sound card if you mean dont have a sound card installed
you might have to uninstall then reinstall both the driver and the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Dec 30, 2010 | Gateway (6000161) Sound Card
I have dell ax210 -2 speakers....I dont have the driver cd....i want the software...
Your speakers don't require any special drivers. All they do is take the analog sound signal from the computer, amplify it and play it for you. If the sound hardware is working, all you need to do is plug in the speakers. The green signal plug goes into the output jack on the computer, and you need to connect the USB plug to an open port for power. Your computer needs driver software for its sound hardware, though, and if you're trying to solve a "no sound" problem, this may be the cause.
You don't give a make and model of your computer or sound card, so I can't give you a specific link. But you can get the drivers from the computer manufacturer's site. If you have a custom-built computer or are using a separate sound card, you'll need to get the sound drivers from the motherboard manufacturer (if it's integrated sound) or sound card manufacturer.
Dec 16, 2010 | Dell AX210 2 Speakers
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Sep 26, 2010 | Dell A215 Computer Speakers
Cant get sound
see your m powerd out put.
Apr 04, 2010 | M-Audio Delta 1010 LT Sound Card
I recenttely hooked up my old gateway compute with the boston speakers and cannot get them to work.. is there some software i need to reinstall to get them working?
on your gateway computer, check to see if you have the volume icon in the bottom right hand corner. If you do then raise the volume up.
If you don't see an icon then that means the sound card drivers are not installed and they need to be to get sound going thru the speakers.
www.gateway.com and go to there support section to get the sound card drivers. I would go there and download the sound card drivers for your computer and then just to make sure you have the speakers hooked up properly go read the manual for the speakers located here:
http://www.bostonacoustics.com/Assets/pdf/manuals/735setup.pdf
Make sure you have adobe reader installed to read the manual.
If you install the sound card drivers and the speakers are hooked up right and your still not getting sound, then that means either the sound card is bad or the onboard sound chip on the motherboard is bad.
Jan 16, 2010 | Boston Acoustics BA735 Computer Speakers
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Jul 04, 2008 | E-Machines eMachines Desktop PC
No sound on my computer
I bought a computer the was rebuild \. My sound is not working at all. I have been online and keep seeing a sound device or sound card is needed. I'm am not to computer savy and I have no idea what this means. Is the sound card and sound device the same? can I order the and just download so tha tI will have sound? Please help. I just so confused right now. What do I need to do so that I can hear on my computer. Even if it is through headphones?
Feb 12, 2008 | Intel Motherboard
Acer AOpen AW 230 Sound Card Logo
225 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
