Question about GE WBSR3140D Top Load Washer
Wbsr3140d washer how do you remove top to get to the basket?
  • 20 Answers
You can remove the front paqnnel by using a knife and releasing the clips holding it on, there is one on each side on the top of the pannel, just take a flashlight and shine it in the crack then stick the knife in to release them, the pannel then lifts right out.
Posted on Feb 13, 2009
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
Water will not run out of washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE WBSR3140D Top Load Washer
After an unbalanced load it started leaking water.
you need to remove the bonnet,(a.k.a. the metal sides) and make sure all the metal sprins are attached to the drum. the round thing,then re assemble. the water coming out is propably from going over the top from your unballanced load.
Feb 16, 2011 | GE WBSR3140D Top Load Washer
GE washer whdsr315 will not agitate, everything else OK How do I get at agitator
Pull off the softener cup
pull of the cap underneath
unscrew the bolt
pull up on top of agitator...it might need persuading
Nov 02, 2009 | GE WBSR3140D Top Load Washer
Nail protruding into inner basket from outside
Hold the basket and remove the nut in the center. It's reverse thread.
Jul 01, 2009 | Whirlpool LSQ8000 Top Load Washer
GE top load washer leaks out of bottom only when filled over half
there is a hose on the bottom it is a manufacture defect. hose is like 8 bucks lasts good yr
Feb 28, 2009 | GE WBSR3140D Top Load Washer
Oil leaking from underneath agitator into the tub of the washer
looks like transmission is leaking, try changing the seal
Jan 13, 2009 | GE WBSR3140D Top Load Washer
Kenmore 40922 front load
This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
Jun 07, 2008 | Kenmore 4292x Front Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
GE WBSR3140D Top Load Washer Logo
176 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
