Question about Celestron 93606 Tripod
Legs lose grip and get shorter! How do i tighten them??? Help!
As mentioned the legs seem loose. When i move my telescope, the legs lose grip and minimize the tripods height. Some legs have it worse than others.. Its so annoying. Please help!
    Sergeant:
    Champion:
  • 373 Answers
I am not sure what kind you have but mine there is grips around the legs you grap and turn and the other one I have has a handle you flip un or down I hope this works out
Posted on Feb 12, 2009
The tripod legs on my manfrotto 3433 slip. the clamping apparatus doesn't have enough grip and just the weight of my video camera is enough to make the legs start sliding down. I see an allen socket...
Hi toolroom347,
There are different clips on the tripod which allow you to adjust the settings for a firmer grip, you also need to extent the gap between the legs of the tripod for a firmer grip, this will help you to set the optimal settings for your tripod which will be fair enough to carry the weight of your camera.
Also a simple solution to stop this slip problem is to carry a small piece of cloth which has guide good grip or a rubber material and then place your camera on it , this will work excellent for a firmer grip.
This has definitely worked for me.
Hope this helps you as well...:)
Aug 26, 2011 | Bogen Communication Bogen Manfrotto 3046...
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Leg clamp tightening adjustment on a 055 tripod.Under weight the leg telescopes in on itself. Clamp doesnot grip tightly enough on the middle diameter leg tube.
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Mar 17, 2009 | Bogen Communication Photography
Plastic locks Vivitar V900 tripod are breaking.
the plastic locks on our vivitor 980 tripod legs are broken now can i replace them. jan
Mar 17, 2009 | Photography
With what can I lubricate the legs onmy aluminum Mafrotto tripod?
Dear Winnieg,
I would avoid using a lubricant on your tripod legs, because you run the risk of the legs not tightening down anymore. I would try cleaning the tripod thoroughly first, because most of the time this is caused by dirt. If that dosen't work I would try rubbing on a small amount of candle wax onto the legs, and then wipe the legs down with a clothe.
Sincerely,
Allan
Go Ahead. Use Us.
Mar 14, 2008 | Photography
Can't figure out how to straighten and level the camera
if you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
Dec 31, 2007 | Quantaray QSX-DigiPro 8500 Tripod
One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
May 26, 2007 | Velbon Ultra MAXi Tripod
Dead Legs on Tripod
I have no ideas, but if you buy another tripod, I owuld like to buy your old handles from your 8500.
Thanx
Rick
817.846.8464
Oct 02, 2006 | Quantaray QSX-DigiPro 8500 Tripod
Celestron 93606 Tripod Logo
287 people viewed this question
Top Celestron Photography Experts
Tony
Are you a Celestron Photography Expert? Answer questions, earn points and help others
