Question about HP Pavilion dv2000z Notebook
  • 95 Answers
Hi you can download the manual from
Posted on Feb 12, 2009
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at See link below. You will need to order 2 batteries
Sep 25, 2010 | Remington Health & Beauty
I need replace a cooler fan but I dont know how to open the computer to get to there.
#1 priority is to disconnect all power including battery. All screws on the bottom of the laptop have a letter which indicates what they are removed for. There is no screws specifically for the fan. You just have to pull all screws and seperate the case. Make sure you keep track of where the screws go. the main thing to remember is when the case is seperate look for the shortest way to get to the fans. Typically each component has a plug. Unplug it and remove it. Try to keep track of the order things are removed. Write it down if need be. Good luck.
Jun 28, 2009 | Dell Inspiron B130 Notebook
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Jun 15, 2009 | HP Pavilion ze5570us Notebook
Bobbem is not right,tread knotting,cant sew
Adjust the bobbin screw tread tension, its too tight.
May 24, 2009 | Sewing Machines
Need to open Averatec 3500 notebook case to replace battery
You have not looked closely enough on top of the keyboard. The keyboard is like on a tray that it can be removed separately, the trick there is... at the top part there, use a flat screw driver to set free the keyboard .... see picture for guidance:
Once detached you'll see your CMOS battery ready for replacement.
Happy Fixya!!!
May 24, 2009 | Averatec 3200 Notebook
Fujitsu Amilo L7310
I have L7310GW - maybe it is similar.
The BIOS battery is deep inside the case and needs full strip down to reach it. I know because I have just taken one apart. Need to undo all screws on base and remove keyboard and screws under that and hinge cover screws and steel plate under keyboard and remove mother board to find it.
Good luck
Jul 09, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
I need to replace frydaddy cover
For a replacement cover call Presto customer service at 800-877-0441. Have the complete model number found on the bottem of the unit.
I starts with 054xxxx. Orders are taken with credit cards.
Feb 18, 2008 | Presto 05420 FryDaddy Deep Fryer
MX6439 Gateway laptop
usally ther is none start bottem take all screws unsnap parts u can pice by pice rember what you doing u will make your way down in it to get mobo out u try changing using new power suplly also 1st or does it have docking staion avible u can charge most throw that
Jan 06, 2008 | Computers & Internet
HP Pavilion dv2000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
