Question about Sharp AL 1631 Copier
My Sharp copier gives a CH error when turned on.
After a few seconds the start button powers off, eventhough the main power is still on. What is this error, and how can I fix it. I assumed that one of the doors was open, but that's not the case.
  • Charlie255 Feb 13, 2009
    what is dv unit?
One of your doors is not shut all the away or dv unit is not installed.
Posted on Feb 12, 2009
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Jul 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Upon power up error code CH is displayed , with second drawer
The steady CH indicates an open right side door. Being that the tray 2 is lit up it could be the side door for the second tray and not the one on the main body. Pull tray 1 and 2 out completely and make sure there is no paper stuck in the machine behind where the tray goes. Double check that both side doors are closing properly and that nothing is broken or missing in that area.
Mar 21, 2009 | Sharp AR-5316 Advanced Digital Imager...
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
New machine
Remove the toner cartridge and reinstall it again. If it appears again turn the power off, wait 30 seconds, and turn the power back on.
Jul 14, 2008 | Sharp AR-5320 Black and White Copier
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
Sharp AL 1631 Copier Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
