Question about Philips Philishave HQ7780 Electric Shaver
Shaving head light HQ7762
Does anyone know how to reset the shave head replacement light on a HQ7762 cool skin shaver
  • Anonymous May 16, 2009
    I have the same problem with my 9160XL.
Diamond E
  • 57 Answers
SOURCE: Philips cool skin shaver fault
The cap of the refill & charge station has not been placed back on the refill & charge station after the refill bottle was placed in the docking station. Make sure you turn the cap clockwise. The battery might also have a cap on its charging, you may need to completely kill it, let it run all night till dead and completely recharge it, let it charge all day or night. A new battery may be needed. This is one thing. The droplet symbol indicates a build up of residue on the sensor. { made to prevent you from buying non philips cleaner} it sounds like a GOOD cleaning will help, ive posted the philips cleaning article on the shaver. http://www.p4c.philips.com/files/h/hq6761_33/hq6761
Posted on Sep 12, 2007
SOURCE: shaving head check indicator still flashing after installing new heads
Apparently you need to change the heads within two weeks after the red LED first starts to flash, otherwise the memory chip inside needs resetting. This also poses a further question. How does the unit know the heads have been changed or not ?
Posted on Feb 09, 2008
MsCtrl
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
Blondie Girl
  • 25 Answers
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
brector3
  • 1612 Answers
SOURCE: The head holder of my Norelco Philips HQ6707 shaver is cracked
You will find a replaceent for model HQ6707 at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-6700-series-cool-skin-head-holder-p-310.html
Posted on Jul 23, 2010
How to get replacement heads for philishave cool skin HQ6761
Compatible blades can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/philips-norelco-hq7-gentlecut-shaving-heads.html
Jun 28, 2014 | Philips Philishave Cool Skin HQ6760/HQ...
Flashing head message
This signal reminds you to replace the shaving heads of your shaver. New shaving heads guarantee continued optimal shaving performance.
What reminder signal your shaver gives depends on the model. Some shavers beep, while others show a flashing shaving head symbol on the display. Some with red half circle arrows, around the 3 shaving heads, or a flash of the 3 shaving heads. There are also models that beep and show a reminder signal on the display at the same time.
How to reset the reminder signal:
The replacement reminder is repeated at 7 to 10 successive shaves, depending on the model.
In some models, you can reset the razor. Press and hold the On/Off button for approximately 10 seconds.
If the shaving head symbol is shown in combination with an exclamation mark ("!") and a faucet symbol, it means that the shaving heads are blocked. When this happens, you have to clean the shaving heads or replace them. (Note: Only certain models have this feature)
Hope this helps, as mine is doing the same thing now.
Jun 22, 2013 | Philips Norelco 1250x Sensotouch 3d...
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
Feb 06, 2013 | Health & Beauty
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
How long are the blades good for
Norelco Cool Skin 7775X electric shaver replacement heads is Norelco HQ177 cool skin shaving heads.
Aug 22, 2010 | Norelco Cool Skin 7775X Electric Shaver
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Is the Braun Activator8595 a good shaver for extra sensitive skin
The Braun foil shavers are well designed and I find they work well for sensitive skin if you prepare properly. Make sure you apply a hot towel to your face followed by a shaving conditioner. When applying the shaver, press lightly. Don't be afraid to go over the same areas several times to get most of the whiskers. Once you do this for about a week, your skin should begin to adapt to the sensation of electric shaving. You'll then be able to use the shaver more aggressively and get a thorough shave.
Apr 04, 2010 | Braun 360° Complete 8985 Electric Shaver
I need a replacement shaving head for norelco 7737x, not just the blades but the entire shaving head.
Here's a source for the replacement heads and cutter blades for your Norelco 7737. If you need any other parts, they also have them available.
http://www.electricshaverstore.com/get_item_hq177_norelco-cool-skin-7000-series-head-set.htm
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Norelco 7737X Electric Shaver
Need shaving heads for hq177 philips shaver, where will i get replacement heads, live in se14 5ae
My store carries the heads for your Norelco shaver. I can ship them to you. Please call toll free 1-888-643-9806 and ask for Action Mike
Jun 06, 2008 | Philips Philishave HQ7780 Electric Shaver
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Philips Philishave HQ7780 Electric Shaver Logo
146 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
