Question about Biostar M7VKG Motherboard
Power reset pin connection problem.
Where do i connect the power reset pin? or can you show me all the connection of the pins? including the jumper settings. i have no manual so please help me!
  • Anonymous Mar 24, 2009
  • 75 Answers
Here is the manual that will definitely sort out your query mate :-)
Lemme know if the solution works mate
Posted on Feb 12, 2009
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Aug 22, 2013 | Gateway Computers & Internet
How to Reset Your BIOS
*Power down your PC.
*Remove the cabinet cover
*Find the 3-pin jumper near the power supply on the motherboard, typically labeled "clear cmos" or "reset bios".
*Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
*Replace the jumper to connect the 2nd and 3rd pins.
*push the power button of ur pc once
*After a min Return the jumper to its default position, connecting the 1st and 2nd pins
* Turn on the PC now,
on Oct 25, 2010 | Computers & Internet
Need to reset tp factor settings for my acer pc
remove the power from CPU then remove the side covers in the motherboard near the c mos battery you will see a three pin jumper with 2 pin shorted remove them and insert the jumper to the 2 and 3 pin then switch on the computer in some case the computer doesn't work switch off and remove the power and replace the jumper to early position and connect the power and restart the computer this will reset the system to default
Oct 27, 2011 | Acer Computers & Internet
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
The person who setup my desktop pc set a password to get into the settings when I press delete.Unfortunately he is no longer around and I don't know what to do I wanted to change settings to boot from cd...
For a DESKTOP (not a LAPTOP) computer ...
Turn the computer off.
Disconnect the power-cord.
Remove the side-panel, to expose the motherboard.
Look for a set of 3 gold pins, in a row, with a "jumper" connecting pins #1 and #2.
The pins may be labelled 'CMOS RESET' or 'CLEAR CMOS'.
Move the jumper to connect pins #2 and #3. Count to 5.
Move the jumper to connect pins #1 and #2.
Replace the side-panel.
Connect the power-cord.
Turn it on -- all the "settings" (including the password) will have been deleted.
Press DELETE to enter BIOS SETUP.
Use 'Load BIOS Default Settings'.
Save/Exit from BIOS SETUP.
Apr 14, 2011 | Computers & Internet
How do I reset it?
Turn the computer on.
When it shows "press <BLAH> to enter BIOS SETUP mode",
press the <BLAH> key.
Select 'Load BIOS defaults'.
Select 'Save & Exit'.
If that resets it, stop here.
Disconnect the AC power.
Open the side-panel on the desktop case, and look for the 'RESET CMOS' label,
close to three gold pins that are in a row. A jumper will be connected to pins #1 and #2.
Move the jumper to connect pins #2 and #3. Count to 30.
Move the jumper back to re-connect pins #1 and #2.
Connect the AC power.
Jan 05, 2011 | Computers & Internet
I need to find the bios reset on the motherboard
Look for THREE gold pins in a row, and a jumper connecting pin #1 to pin #2.
With the computer turned off, and the AC power *UNPLUGGED*, move the jumper from #1/#2 to #2/#3, wait 5 seconds, and move the jumper back to the #1/#2 position.
You have just "reset" the BIOS.
Aug 22, 2010 | MSI K8MM-V Motherboard
Remove or reset bios password on dell optiplex gx270 disktop with vista home edition. dell motherboard tried removal of battery didnt work
Look closely at the motherboard, for 3 gold pins in a row, with a "jumper" between two of the pins, say pin 1 (end) and pin 2 (centre).
Move the jumper to connect pin 2 (centre) to pin 3 (other end).
Count to five.
Move the jumper back to its original position.
Voila! You have "reset" the BIOS, and have deleted the password.
Apr 10, 2010 | Dell OptiPlex GX270 PC Desktop
I have a compaq 5000 and I forgot my power on password can you help me
you need to open the CPU, be sure the CPU is unplug the energy, you need search the clear CMOS pins in the main board, they have a mini black plastic square, you need to put this in the 2 pins, this generate a shortcut and reset the CMOS to original state, this don't erease anythig else, only the date, time and POWER PASSWORD. ok
TIP: whe you put the mini black plastic square in the pins you can ONLY RE-CONNECT THE POWER CORD for a few secons, then unplug the power cord again and keep the mini black plastic square and put this in only one pin, YOU NEVER RUN THE MACHINE WHIT THIS MINI BLACK PLASTIC SQUARE OR DAMAGE THE MAIN SYSTEM BOARD FOREVER!!!!!
Nov 26, 2008 | Compaq Presario 5000 PC Desktop
Where are the EliteGroup nForce3-A power & reset plug-ins located at?
Goto page 10 in your user manual. There look for. Connect the case switches and indicator LEDs to the SW1. (Location).
There is mother board layout decription for how to connect the case, 2-pin wires case connectors ( Page 12 shows pin numbers & which is plus + & negative - pins.). You'll nee the manual to help you. Download it from ECS at:
Aug 12, 2008 | EliteGroup nForce3-A Motherboard
Biostar M7VKG Motherboard Logo
82 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
