Question about Canon FAX-L1000 Plain Paper Laser
I want to turn off the dialing tone
The machine makes a very annoying dialing tone when I am sending faxes - someone has turned this on and I want to know how to turn this off!! Urgent as it's driving everyone in the office mad!
  • 1,219 Answers
Under user mode ( MENU) - machine sett. - buzzer - off
Posted on Jun 14, 2010
Kodak all in one problems
g"> your cartrige chip is wrong
Jan 14, 2014 | Office Equipment & Supplies
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
Error code 48
Code 48 is internet disconnect.
On the machine if the machine is set up for internet connection, turn it off. Sometimes email is turned on and the other settings are not setup correctly.
Make sure all settings are done correctly
If one is faxing make sure the phone line is connected correctly and their is a good sounding dial tone.
One area to keep in mind is a phone dial tone turning off and on.This can be a phone company issue or poor line connectors in the building, even a corroded plug on the phone receptical.
Check these areas, even replace the phone line cord with a new one.
On the machine a fax machine not sending or recieivng, suspect a board causing the problem.
Jun 08, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Faxing
you could try pressing the on hook dial button once you have a dial tone dial the fax number you are trying to reach and then you will be able to hear f there is a fax tone form the other machine or a error message from your operator. If there is a series of beeps with the document in the feeder press send.
The most common cause of not sending is ECM (Error Correction Mode) press menu and within TTI settings make sure this is turned off.
Hope this helps you
Thanks J
Jul 26, 2006 | Brother IntelliFAX 560 Plain Paper Fax
Canon FAX-L1000 Plain Paper Laser Logo
81 people viewed this question
old marine
old marine
