Question about AudioTrak MAYA 44 USB External Sound System
Problem with Maya44 USB Outputs
I am using the Maya44 USB soundcard with virtual DJ, When I hook up the RCA Cables, the inputs 1,2,3,& 4 work fine, but all of the sound for all 4 channels come out of output 1 & 2. Why are channels 3 & 4 outputs not working? How do I reconfigure?
  • bunset Mar 31, 2009
    I have the same problem and I am desperate too
    I cant use outputs 3 and 4 with virtual dj
ENSURE YOU PLUG YOUR SOUND CARD INTO YOUR PC/LAPTOP BEFORE BOOTING IT UP THIS SHOULD DETECT THE CARD
Posted on Jan 25, 2010
You need to make sure of the following:
In the ASIO driver settings the outputs are not checked to GANG.
Set your output from virtual dj as an external mixer and select the MAYA 44 Soundcard Option from the drop down.
If you audio isn't playing reinstall the drivers for the sound card.
Unfortunately I have to do this everytime I set up for a gig which is a pain but I am looking to find a reason as to why my pc doesn't pickup the Device in ASIO after a reboot unless I reinstall.
Anyway less of the babling hope this has solved your query!
Posted on Sep 17, 2009
    Problem Solver:
  • 7 Answers
Yes
Posted on Feb 13, 2009
What could be the cause of my m audio m track soundcard making inner noise like a radio is turned on
I have had a similar issue and discovered one of my audio cables wasn't properly shielded. Try a new set of cables including the USB cable. If there's bad shielding or ground on any of your cables it can pick up outside interference. Also, try each input cable one at a time to try to narrow down which cable or input it could be. If you get the interference with a new USB cable and nothing plugged into the unit there could be a bad ground in one of the XLR or 1/4" input.
Sep 22, 2014 | M-Audio MTRACK USB Audio Interface w/...
Put wrong power supply into unit
You probably blew it. It sounds like the power supply put out more voltage then needed. Also they come in AC/DC, putting AC into a DC input usually blows things, dC into an AC normally does not hurt it assuming the voltages are in range in all cases.
Jan 12, 2013 | American Audio VMS2 VMS702 Table Top MIDI...
I have a turntable with a white and a red male RCA output cable. I am trying to hook it up to a Marathon DJ-1000 amp which has two TRS input channels - Channel 1 and Channel 2. Should I buy a twin female...
If I understand you correctly each channel has a single input in the amp, then yes! white goes into channel 1 and the red plug goes to channel 2 this way your signal will be stronger which translates into louder sound.
Jan 25, 2011 | RCA Audio Players & Recorders
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
I JUST GOT VIRTUAL DJ AND I WHANT TO NOW HOW TO SET UP MY PC WITH THE DENON S3500
You need an external asio supported soundcard such as maya44 usb or american audio versaport (recomended)
Mar 03, 2010 | Denon DN-S3500
HI,just bought a ion icue computer dj system and i am getting interferance everytime i try to mix using the fader or the togs or anything thats hands on.
I gues by interference you mean stuttering, its probably your soundcard. Get a card that's ASIO capable like the MAYA44 (about £45) and you can also have two outputs (i.e. monitoring)
Aug 29, 2009 | 2006 Saturn ION
Ringing sound in background
sounds like there is a input to output loop of some kind. On some of my soundcards I was able to configure a virtual patchbay. Check around in the software for this and macke sure outputs are to outputs and ins to ins. Good luck.
Aug 28, 2009 | Rane Serato Scratch Live Computer DJ...
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
SOund comes out distorted
are you using timecodes if you are go to config and dont select maya 44 put asio then put asio config on the side and look for the volumes and ajust them
Feb 15, 2008 | AudioTrak MAYA 44 USB External Sound...
AudioTrak MAYA 44 USB External Sound System Logo
1,062 people viewed this question
Top AudioTrak Computers & Internet Experts
David Payne
David Payne
Are you an AudioTrak Computer and Internet Expert? Answer questions, earn points and help others
