Question about Samsung TXG2746 27" TV
STB with Magnavox remote (need codes) - Samsung #TXK2766
Remote turns on/off the STB for digital conversion; but no response for channels, volume - probably need codes. Right? Where do I find?
Did extensive checking and finally found out that the remote for Magnavox TB100MW9 analog/digital converter is not made for volume control. The channel changing buttons are half-way operable--sometimes yes, sometimes no--and to think they call this a remote! Therefore you must keep the other TV ready remote that you have been using (tape them together probably) for volume and mostly channel change. I know what Magnavox can do with these remotes - and you know how much more Magnavox I will be buying in the future. Nada, none,---from a very disappointed, frustrated customer.
Posted on Feb 13, 2009
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Code for magnavox converter box tb100mw9
You need a recent model RCA or possibly Philips universal remote that contains specific codes for the Magnavox STB.
Oct 12, 2016 | Magnavox Tb100mw9 Digital Tv Converter Box...
What is the STB code for the NA386UD remote that comes with the TB110MW9 Magnavox digital/analog converter box??
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 09, 2014 | Magnavox Remote Control Unit / Na386ud
Ii'm trying to program a magnavox universal remote
My Magnavox STB instructions say that if Magnavox codes do not work you should try Sylvania. My Philips/Magnavox universal remote instructions list the same codes for both so here they are: 002, 009, 109, 118, 209, 309, 402, 408
Nov 16, 2012 | Televison & Video
My dog ate the remote for my Magnavox TB110MW9 stb. I have the code and a new universal remote. HOW can I program the remote when there is no way to turn on the box manually??
Setup codes for Magnavox STB with universal remote are:
0576 0612 0639
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 28, 2012 | GE Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Mar 29, 2009 | Televison & Video
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Televison & Video Logo
586 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
