Question about Zenith XBR413 DVD Recorder
Viewing Why is it that when I record from my Zenith VHS to the DVD combo player, it records but I an unable to view it on any other machine. It records and will play back on this device, but when I put it in a different DVD player, it cannot load or play.
  • 679 Answers
Check out the recording speed.
Posted on Feb 12, 2009
  • rockfixya
    rockfixya Feb 12, 2009
    It seems the media your recording on is either too slow for the player and the player is recording faster than the media is supposed to handle. For some reason it works on the machine it was recorded on but nothing else.
    Try: Get media that matches the speed of the player.
    Thanks for using FixYa.
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the...
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Regards,
BElectric
Feb 17, 2011 | GoVideo Go Video DVD/VCR Combo
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Zenith XBS245 DVD/VHS combo need type of disks
Try here
Hope this helps!
-Curtis
Rate my solution please!
Feb 01, 2009 | Zenith XBV243 DVD Player/VCR
Type of dvd my player takes
According to what I find on the XBS245, it's not a DVD recorder.
Recorded dvd's won't play in another dvr
The problem is not the dvds themselfs it is the other play that you are trying to play them in (some players do not play DVD- and DVD+ or any other of self recorded disks) Look on the players box to see all what types of disks it can play!
Please rate answer and help keep this site free
Jan 03, 2009 | Zenith XBR716
Recording from tv
the line out from your tv has to run into the line in on vhs/dvd player
Dec 27, 2008 | Zenith XBR716
Dvd Recorders
Most DVD recorders have a "Scart" input. I assume your VHS has one also. conect a scart lead form the VHS to "Input" scart on DVD recorder. Select the "scource" of viewing on the DVD to "Scart", press record on the DVD and "Play" on the VHS and away you go. You should be able to view whats happening on your T.V. when you select the scart that the DVD is connected to on it.
Jul 26, 2008 | Sony RDR-HX520 DVD Recorder
Viewing
you have to finalize the disc first.once it is finalized you can not record any more material on it,so make sure you record everything you want on a disc. you can maximize disc space by changing speeds on the dvd recorder. for example: if you have 5 hrs of stuff on a tape, set the dvd recorder for 6 hrs or more recording time.the quality should be ok [depends on how good of quality you want] if you set the speed for 2 hrs, your quality would be better, but obviously everything won't fit.
hope this helps
wg
Jan 30, 2008 | Zenith XBR413 DVD Recorder
Viewing a recorded DVD+R on PC
I am assuming you have an actual dvd drive of some sort installed in your computer. The problem you may be having is a missing codec. This problem can be solved by downloading a VLC player which has most needed codecs pre installed. This program is freeware and can be easily found online. I hope this helps. Good Luck!
Jan 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith XBR413 DVD Recorder Logo
37 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
