Question about Maytag MER6772 Gemini Electric Kitchen Range
Oven won't stay hot
I turn my Maytag oven on to a certain temperature and the element lights up but will not stay hot. Could you tell me what could be wrong?
  • Mark Egan May 11, 2010
    If it's not tripping a circuit breaker, and the oven is just not coming up to temperature, yet the elements do get hot, then it's either the thermostat or the door sensor.
    And, elements do not normally "light up" or glow because if they do, they will fail much sooner than they should. If this is happening, then there may be some other problem that needs to be diagnosed.
    Reply back with a few more speicifics and we can help you more.
  • 3,640 Answers
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG
Posted on May 14, 2010
Bottom oven on Magtag Gemini burning bottoms of everything
when you set oven on bake the broil element comes on too,set the bottom oven on broil and see if the element gets hot,if not,unplug the machine or kill the power going to it,remove the element and check it with a meter to see if the element is bad,if so change out broil element if element is good you could have a broken wire or bad clock assy.there's a computer board with the clock that everything runs through,hopefully you have a bad element,if the element is coming on next thing to check is the sensor,this tells the computer how hot it is so it will turn the elements on and off,if you look behind the top panel in the back i think the paperwork is in a plastic pouch,it will tell you how to read out the sensor,i think it's 1080 ohms,or you can read out the sensor on the top oven and then check the bottom sensor and hopefully it will be a bad broil element or sensor and not the clock assy. hope this helps.
Feb 27, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
Aug 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Maytag electric range, older model. What is a beeping, flashing code F2
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
Jul 06, 2011 | Maytag Ovens
The oven does not cook the food, it only warms the food.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature.
If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired.
If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Feb 10, 2011 | Viking Ovens
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
Oven over heats and gives a 1D11 fault
I have a similar unit with a similar problem, and found the Maytag troubleshooting manual online. Code 1d11 means the the unit reached 600 degrees (not supposed to get that hot). Basically, it had a runaway temperature. The computer does not know why it happened, so it just tells you that it happened by showing code 1d11. But you can tell what went wrong by your description of the problem: the broiler element was turned on without any command from you. Which means the swithc/relay in the electronic control unit is bad. I am guessing it was fried when you ran the oven through the self-cleaning phase (should not get fried with this little of heat--it was defective to begin with). Mine just went bad after 4 years of use. You can get an electronic control unit for this unit for around $170 at Sears online parts store. Notice that Maytag has replaced the old part number for this electronic control unit with a new one, which probably means they had a design flaw and have fixed it.
Oct 23, 2008 | Jenn-Air JES9800BAS Electric Kitchen Range
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Maytag MER6772 Gemini Electric Kitchen Range Logo
393 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
