Question about Brother HL 1430 Laser Printer
MACHINE WON"T PRINT
Mf5770 red alarm flashing on front panel display wants me to check paper size done that did"nt help what do i do
  • 62 Answers
There is a sensor that the paper tray hits to make sure the paper is in the tray. If you have made sure the paper is not to tight in tray (needs to be set a hair longer than the paper is) then it may be the sensor that is out of adjustment. A tech will be the only one who will know how to put it back into adjustment.
Posted on Feb 12, 2009
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
My MF5770 display alternates between "Change papersize" and "Check papersize" and will not print. Turning off does not solve the issue, nor does going thru' the menu to change...
You have to check both trays, the cassette and the manual feed:
The Cassette:
Remove the paper tray and inspect everything.. remove the paper, move all of the paper guides and make sure they all lock into place where they should (LTR, LGL, etc)
if the paper size guides are broken/damaged then the machine may not be able to correctly tell the size.
The Manual Feed:
Open up the front door, remove the toner and check the area around the manual feed. You're looking for the flag that tells the machine there's paper in the MFT. If this is stuck it's possible it's incorrectly trying to pull from there.
Jun 01, 2011 | Office Equipment & Supplies
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Canon MF5700 Series all in one printer
Throw it in the trash. It's a piece of shi*. I'm sick of mine.
Jun 25, 2008 | Canon ImageClass MF5770 Laser Copier...
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Jun 01, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
The printer keeps saying check the paper size when its the same paper , we have been using from a very long time
Confirming/Deleting a Print Job
  1. Press <Status Monitor>.
  2. Press <la.gif> or <ra.gif> to select [PRINT], then press <Set>.
    If there is no job, [NO PRINT JOB EXIST] is displayed.
  3. If you decide to delete the current print job, press <la.gif> for [YES].
    • To cancel deleting the job, press <ra.gif> for [NO].
    • Once the job is deleted, the job cannot be restored.
    • If the alarm light is flashing, open and close the front panel to reset the alarm.
Apr 07, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
Mf5770
DOOR AJAR, JAM, OR PM LIGHT WHAT TYPE OF LIGHT OR CODE DO YOU HAVE
Dec 31, 2007 | Canon USA - COPIERS - CLC 5000+ (PLUS)...
Alarm light is on it says( check paper size) this is a canon mf57700
I had this problem also. I was unable to clear the paper size error. Finally I loaded the papersize that the printer was wanting (A4 in my case) and let it print. Once the print job finished it was back to working normal.
Oct 22, 2007 | Canon ImageClass MF5770 Laser Copier...
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
Brother HL 1430 Laser Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
