Question about NetGear WGR614 Wireless Router
WGR614 v6 will not connect through LAN????
I have not used the wireless for some time now? but when I tried to connect through the wireless via lan. The laptop acer 5520 will not connect!!!! please help......... The system is set up via WEP......
  • Anonymous Mar 27, 2009
    Netgear wireless router periodically looses internet connection though continues to recognize other machines on LAN, I can reboot the router and the internet then becomes accessible. REBOOTING IS A PAIN. Is it looses a dynamically set IP address being changed by the internet provider (cable)?
    Scholar:
  • 141 Answers
Did you call NETGEAR already? Maybe your WEP was changed. If you can't fix this try http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Trying to set up laptop from desktop but dont know password for router wgr614
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | NetGear WGR614 Wireless Router
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Connected WGR614 v6 to DG814. Have internet light on, no wifi. Can't connect to the WGR614 via lan from pc. Tried to hard reset nothing happens. The PC and DG814 show connection to the WGR614 but can not...
Is this the initial set-up of the network? Sometimes it just needs to be rebooted a few times to connect. The way to reboot the network is to turn off the computers, then unplug the router, next unplug the modem. wait about 30/60 seconds then plug in the power to the modem. Wait for the modem to fully boot. Wait a minute or two, then plug in the power to the router. Wait till it has booted, another minute or two. Once the router is fully booted, then turn on the pc and check to see if it connects. If the computer was previously connected to the modem, before the router was incorporated, it still has the ip address assigned by the modem and has trouble releasing it and getting an ip address from the router.
Dec 02, 2009 | NetGear WGR614 Wireless Router
Xbox live problem
If you cannot connect using the wireless because the signal strength is too low, you can connect the Xbox using a LAN cable to the router. You might need someone to install the LAN cable for you depending upon how you can locate neatly.
Sep 26, 2009 | NetGear WGR614 Wireless Router
Cannot connect to my Netgear WRG614 v6 Router. My Dell laptop shows an excellent connection but it says limited or no conectivity? I have tried several suggestions and reseting several times...nothing...
If you are using LAN cable from your ISP. Try to connect it to your Computer LAN port directly or how you connect directly your internet connection from your computer without the router. Then on your system tray try to look the internet icon activity usually a two monitor icon. Right click on there. Then select status,then support, then details, from there see the DNS number you may get two DNS numbers set then put that manually to your wireless lan settings.
Jun 06, 2009 | Computers & Internet
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Dec 21, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
137 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
