Question about La Crosse Projection Alarm Clock with Temperature and Humidity Display
Merchsource Shift 3 Projection Alarm clock - No Battery Backup
I received this clock at Christmas, and I thought it was great until I had a power failure. Apparently the batteries in the base only work if you happen to unplug the power supply from the unit right when the power goes out. You can see the problem by just unplugging the power supply only from the wall, and then after waiting a little while, plugging it back in. The clock does not have a battery backup, but it requires batteries - Go figure!
So I have been looking and looking for their Web site and it does not exist. Does anyone have it?
I did find a phone number in the Yellow Pages, and i will try it when I can - 949-900-0900.
  • dkp2155 Feb 15, 2009
    need manual but can not find website.
  • Anonymous Apr 14, 2009
    yeah...i just bought it like a few minutes ago. Having battery doesn't do jack. If your power goes out, you need to redo everything, including opening and resetting the remote.
3 Suggested Answers
SOURCE: Shift 3 Projection Alarm clock remote cannot open
There are four small phillips head screws that hold on the back cover. Just take a small phillips screw driver, unscrew the screws, remove the cover and insert two (2) AAA batteries. My problem is that the main unit does not recieve the outside temperature from the sensor.
Posted on Feb 06, 2009
SOURCE: Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Posted on Nov 14, 2009
Lost instructions for Shift Model No 1624965
I am trying to find the instruction manual for the Shift 3 FC Model 1624965 also!! The back says Made in China, Merchsource LLC, Foothill Ranch CA. Anyone? Just found an interesting report on Merchsource. See link: http://www.ripoffreport.com/r/merchsource-llc/foothill-ranch-california-92610/merchsource-llc-discovery-kids-scam-distributor-for-discovery-kids-foothill-ranch-califor-677328
Maybe we will NEVER figure out how this clock works..
Mar 23, 2013 | Measuring Tools & Sensors
I need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Which the voltage of the transformer to be replaced
Hello
Your clock has a backup battery. Battery is for time backup only.
The clock and alarm memory will
be retained during a power
interruption. During battery
backup operation, the display
will not light up, but the correct
time will be maintained internally
The mains transformer inside it will be of 10.2vAC secondary to 120VAC primary. OK.
May 13, 2011 | GPX CRCD2806 Clock Radio
I got the clock from my daughter and have no manual. I keep setting the time, and it keeps changing to 2 hours earlier. I think I've pretty much figured out everything else, though this is NOT intuitive.
Hi, your clock radio is an atomic clock radio... no wait you don't need your lead underwear! it receives a signal from the atomic clock and sets the time to match it, after you set the time zone and put it on auto dst you will never have to set the time again!
ENVIRONMENTAL RECEPTION EFFECTS:
The Atomic Clock obtains the accurate time with wireless technology. Same as all wireless devices, the receiving ability may be affected by, but not limited to, the following circumstances:
  • Long transmitting distance.
  • Nearby mountains and valleys.
  • Among tall buildings.
  • Near railway, high voltage cable, etc.
  • Near freeway, airport, etc.
  • Near construction site.
  • Inside concrete buildings.
  • Near electrical appliances.
  • Near computers and televisions.
  • Bad weather locally or electrical storms between you and Colorado.
  • Inside moving vehicles.
  • Nearby metallic structures.
LOCATION PRECAUTIONS:
This clock receives a radio wave much like a TV or radio. Be sure to locate it near a window or some other location where reception is good. Avoid the following locations, which can interfere with proper reception.
Synchronization signal reception can be received in Continental USA only. In other areas, you can still use this clock by making time settings manually.
QUICKSTART
  1. Place your clock in a location with optimal signal marks on the LCD.
  2. It is recommended to put the clock near a window. Please move the clock to another location if difficulty in signal reception or unstable signal marks is encountered.
Installation
Simply plug the SkyScan clock radio into any household outlet.
Battery Back-up Operation
This clock radio is equipped with alarm time memory that can be powered with a 9-volt battery (not included).When normal household power is interrupted, or the AC cord is unplugged, the battery will power the clock to keep track of the time and set alarm. When the backup battery activates, the LCD backlight is off, however, the functions of alarm and radio still operate.
To Install the Battery
  1. Remove the battery cover at the bottom of the case.
  2. Connect a 9-volt battery to the connector plug.
  3. Insert the battery in the compartment and replace the cover.
Note: An Alkaline battery is recommended. Carbon Zinc and rechargeable (nickel cadmium) batteries not recommended.
Set the Time Zone Press the SET button in sequence until you see PST(Pacific Standard Time)blinking below the time digits on the LCD. Press UP or DOWN button to select your time zone.
Daylight Savings Time
Always slide the DST switch to ON position unless the clock is used in an area without Daylight Savings Time.
**Special attention to usage in Arizona and Indiana. **Arizona and parts of Indiana do not recognize Daylight Savings Time (DST). Turn the DST off if the clock is used in these areas.
Cheers!
Feb 16, 2010 | SkyScan 34202 Clock Radio
Aug 02, 2009 | La Crosse Projection Alarm Clock with...
Shift 3 projection alarm clock cannot connect with the remote
Did you put two AAA batteries in the remote? Use a small phillips to take the cover off of it. Then hold channel on the main unit for three seconds to synch it with the remote.
Mar 14, 2009 | La Crosse Projection Alarm Clock with...
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
Feb 06, 2009 | La Crosse Projection Alarm Clock with...
Can't set alarm
Push the center botton on the back until you see WAKE I and then by holding it dwon push the bottons on either the right ir left of that button to set the alarm.... same process for WAKE 2...just have to push the center botton again
Jan 05, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Alarm function ats 909
To cancel the alarm press the "C" button. "C" equals cancel. You need to be in the set alarm mode for this to work.
Dec 21, 2007 | Sangean ATS 909 AM/FM/SW Radio
La Crosse Projection Alarm Clock with Temperature and Humidity Display Logo
558 people viewed this question
Top La Crosse Audio Players & Recorders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
