Question about Sansui Televison & Video
Does my TV have a digital tuner?
This TV is in our RV and I would like to know if it going to work on the roof antenna after the changeover ?
  • 4,234 Answers
Without a make and model I can not say. But, let me state that if the set is older than 2005, you will likely need the converter box. Please update this with the make and model and I will confirm.
Thanks,
Dan
Posted on Feb 12, 2009
I have in car television fitted in my car and now cannot receive signal after changeover to digital what can i do
do you have a digital tuner for this tv, if not you will need one. Tv stations are no longer carrying an analog signal so you have no choice but to have a digital tuner and antenna. Good Luck.
Sep 07, 2011 | Car Audio & Video
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
I have 50" PF9966 flat TV , not sure if is HD ready ? 2006 model how do i find out , nothing showing in guide
There are a few things to consider here. First, if you are using cable or satelite, the changeover has no effect on you anyway. If you are using an antenna, the changeover to a digital broadcast signal has already been in place for a while. The set should be able to auto-detect these signals. I believe that most of the models from 2005 on had digital signal tuners available. This is not the same as a "digital" tuner. A digital tuner only means that the stations are tuned digitally but are still analog signals. The changeover will be to change the analog signals to digital ones that require a smaller frequesny band for broadcast thus opening up more space for additional channels.
Hope this helps,
Dan
Jan 05, 2009 | Televison & Video
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Dec 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Is the sony kv-32v35 digital ready?
if the tv is less than two yrs old than yes.
Dec 20, 2008 | Sony KV-32V35 TV
Televison & Video Logo
57 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
