Question about Gateway MT6705 Notebook
Formatting problem I have to change my hard drive to a new one and use xp on it but the system cant find the new drive to boot
  • Frank
    Frank May 11, 2010
    is this a unformated new hard drive?
    if it is, then you need to format it with Windows XP installation CD.
    insert the CD and turn of the machine. follow the instructions.
  • 95 Answers
Have you already installed the OS? Go to select the boot option manually by going into the bios or set up screen when on the boot screen
Posted on Feb 12, 2009
    Problem Solver:
  • 18 Answers
Does the new drive have XP on it already?
If not just boot from the XP disc and you should be able to do it from there.
  • Josh Ryals
    Josh Ryals Feb 12, 2009
    If it has XP on it, hook it up as a slave to a different machine, format it and start over.
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
Problem is (the dist structure is corrupted and unreadable). please help
Hi, looks like you will need to format your hard drive and reinstall windows. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 01, 2010 | Computers & Internet
Windows XP SP2 will not boot after installing new SATA hard drive
Your system thinks the "second" drive has precedence over the first ( your boot drive ) try switching the SATA cables between the two drives. There also might be a BIOS setting under Boot Order, sometimes you have to drill down to get to it for a particular drive.
Dec 25, 2008 | Microsoft Windows XP Professional for PC
Error loading operating system
Firstly have you set your jumpers on your hard drive setting before placing into computer. If not check if the cd rom is on the same cable, if on same cable then change the jumper.
Have you gone into bios and loaded the hard drive. If a new hard drive you will need to detect it in bios first. Then Save and exit.
To go into bios, press f1 or f2 or DEL when you first start computer. Each computer is differentand you'll have to see which you require to press.
After bios is setup, put in your copy of windows xp, or your boot disks and follow instructions to set partition and format drive, then install operating system.
If you are only installing a new secondary drive as a backup, you will still need to detect in bios first. Then load you windows and go to my computer and format the drive using windows.
Aug 05, 2008 | Computers & Internet
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
ACER 4720Z
seems that it's a SATA drive and the drivers are not included in XP.
There are some tools available to include these drivers into the XP CD.
Search the net for 'xp-iso-builder' or 'n-Lite'.
This is not necessary if your laptop's got a floppy drive (i don't think so). Then the SATA drivers can easily be loaded by pressing F6 when booting from the XP CD.
Mar 02, 2008 | Microsoft Windows Vista Ultimate Edition
Installing Windows on new PC with Sata hard drive with no operating system installed
press any key to boot...
usually that comes up when a cd is inserted and its waiting for you to press a key so that it boots the cd
Formatting shouldn't be necessary if its a new pc unless your trying to get rid of the operating system.
Are you trying to install windows xp / vista ?
Feb 22, 2008 | Computers & Internet
Presario 900 -- How to format the system?
cant use recorvery ok u need to get xp cd boot into it says it all formatt then install new update ect
Feb 04, 2008 | Compaq 100GB Laptop for Presario 900 &...
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Gateway MT6705 Notebook Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
