Question about Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
How do you replece the door seal on a hotpoint Aquarius WF210 washing machine? Ta.
Sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Posted on Feb 13, 2009
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
The door sensor for a Hotpoint Aquarius WF210 the light comes on and then flashes off and the door don't lock what can i do?
More than likely the door interlock has failed if the machine won't start and or lock..If so, not a big job for a tech to replace.....Nomess
Apr 04, 2010 | Washing Machines
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf210 filter location?
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Require a manual for Hotpoint Aquarius WF210 washing machine
You cannot download a repair manual on line, you have to purchase them from Hotpoint,
However, if it is a user manual you require, then go to:
WWW.HOTPOINT.CO.UK
Click on after sales, and then on download instruction books, put your model in the box, and then you can download to your computer. or to your printer.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine door will not open
remove the front kick panel. feel at the back of the door switch, there is a plastic thing with a ring at the bottom, pull this down and you can hear a click at the door switch and you can open it now. that is the manual door opener. make sure there are no more water inside or you'll make a mess.
tnx 4 using fixya,
drcool
Oct 26, 2008 | Hotpoint Aquarius WF210 Front Load Washer
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
Aug 23, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
