Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Interior light remains on when the door is closed
The light housing and and the metal reflecting plate heated up so much that the plastic mounting screws melted. This caused the whole temperature display and light mounting to seperate from the refrigerator. The extreme heat also burned a hole in the inside casing of the referator itself. We have removed the bulbs as a temporary solution. Sears refuses to address this issue even though a fire could have resulted from the extreme amount of heat generated.
    President:
  • Kenmore Master
  • 2,651 Answers
I believe this refrig, is produced by the LG corp, ofr kenmore, they do have a repair for this issue, ( i just changed one last month), which inckluded replaing hte light housing(the new one has a high limit thermostat to cutt off lights in case of this prblem) as well as replacing hte main control board behind the unit.scream safety issue!!!!!
Posted on Feb 13, 2009
How do you install an Ikea kitchen cabinet door hinge?
The new Ikea Sektion door hinges mount in 2 holes that are horizontal. The dimensions for the hole placement are 62 mm up from the outside bottom of the cabinet where the bottom edge of the door will be. The first hole is 20 mm in from the front edge and the second hole is 33 mm from the first hole or 53 mm from the front edge. The holes can be drilled with a 3/16" bit to a depth of 9/16". After the holes are drilled, the plastic plugs on the back of the hinge mounting plate are pushed into the holes with the orientation triangle "arrow" stamped on the front of the mounting plate pointing toward the cabinet opening. After the mounting plate is flush with the surface, the two wood screws are tightened in the plastic plugs to expand the plugs and secure the mounting plate. The door hinge mounted to the door is then clipped onto the mounting plate by first engaging the "hooks" near the door end of the hinge then snapping the back end of the hinge into the clip at the rear of the mounting plate. The location of the door once mounted can be adjusted by turning the three screws on the hinge. The front screw moves the door right and left when closed. The center screw (recessed in the hinge) moves the door up and down. The back screw moves the door closer or farther from the cabinet when closed. The hinges "snap" the door closed, so if the door is too close to the cabinet the hinges can't snap it closed and the door remains ajar. The trick is to adjust the inner screw to move the door farther from the cabinet until it snaps closed. The snap can be strong, and the little bumper plastic disks you can stick to the door to soften the bump work to some extent. The best solution is to install one soft-close Utrusta piston per door. The piston clicks onto the hinge and slowly closes the door the last bit without a bang.
Jan 31, 2013 | Hardware & Accessories
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
How do you replace license plate bulb 2005 cadillac srx
First you have to take out the one and only screw in the rear hatch door - it's where the hand pull down is you use to close the hatch.
Then you have to pop all the plastic clips all the way around the plastic door panel, trying not to pull them out from the frame . If you do pull out the white plastic plugs from the frame you better make certain you take them off the plastic housing and insert them back into their frame holes - or you will never get the housing back on.
Once you have the housing loose disconnect the inside tail gate light wire to remove the whole thing. Then you have to remove 7 to 8 nuts from the back of entire License plate, back up bulb housing using a deep socket to get in there. Work it loose from the rear of the car and it will come out just enough to work on the lights.
This is tricky since the screw mounts don't give you much room to work with.
Once you have the license plate and back up bulb frame loose you will see the two housings for the license plate bulbs on top.
Slide out the license plate bulb lens and twist the bulb connection to remove the bulbs.
Replace both of them - you don't want to do this again in a month when the other one blows.
OPTIONAL:
Once you take out the bulbs you might see that the housing is melted where the bulb wanted to burn through. Drill two small holes one is each end of the housing before I put everything back together to release some of the heat.
Reverse the whole process to put everything back together. It's not easy.
Make sure you insert the cables through the opening for the hatch handle or it will kink and not work properly.
The bulbs come in a two pack of cost $4.95 .
Take care
Jul 28, 2010 | Cadillac SRX Cars & Trucks
Rear liscese plate bulbs on 05 cadillac srx
OPTIONAL:
Nov 24, 2009 | 2005 Cadillac SRX
I have a wr and number plate keeps getting friyed can you help
Go to a metal fabrication shop (machine shop) and have them make an aluminum plate the same size as the number plate. Now get longer screws and mount the metal plate and plastic plate but with a 1/4" spacer between the plastic and metal plates. Now the heat won't fry the plastic and the metal plate is extremely light.
Oct 28, 2009 | 2002 Yamaha WR 426 F
2001 Toyota Sequoia lift gate latch broken, door is locked closed
Take a look at my other Sequoia posts about this.
You need to remove the interior pull handle first then gently pry away the interior panels from the top down. Go look at Tundra Solutions.com for the detailed procedure on the handle assemlby replacement but here is a rundown:
First, take off the license plate2_bing.gif.
Since the hatch wouldn't open, I started from the inside and took down the top trim piece. After that the two side pieces come down, then the main trim piece which covers the bulk of the door comes out. These are all popped in with the white tabs.
There are 3 access hole covers to pop out (don't forget to install them back in when done) and through the left hole you can see the mechanism to unlatch, press it down with a screwdriver and open the door. If anytime you close the door you will have to do this to unlatch, up until you disconnect the cable and pull out the handle, then you have to locate the cable and pull that directly.
Behind the large trim piece you will find a metal access cover, remove the 7 or 8 10mm bolts holding that on and pop the 3 white tabs and let it hang off to the side. Disconnect the cable from the handle assembly by reaching in from the right hand side and popping of the cable from the handle assembly.
From the left and right access holes, locate the two 10mm nuts which hold the license plate assembly to the door and remove them. Then there are 4 plastic tabs that come in from the outside that hold the license plate assembly on in each corner, try and locate those and using some pliers squeeze them together and push it through. Next locate the license plate lamps wire connector and release that from the left side, it’s the simple push in and pull out square white connector.
After these are out, put back in 1 or 2 bolts into the large metal access cover so the hatch can be lowered (don’t close it).
Here is where I had fun, begin to pop out the assembly that it was bolted to. I ended up breaking 3 of the 4 plastic tabs in each corner because I did not use pliers from the other side to pull them out, however it remained somewhat useable (hindsight 20/20).
Now the license plate assembly can be taken to a bench to replace the handle assembly (Toyota doesn't sell just the handle, it is a small assembly). Two screws out and the assembly is replaced.
Before pressing the license plate assembly back onto the truck, make certain all the plastic tabs are in the assembly and not in the truck. Reverse the process to re-install.
Sep 07, 2009 | 2001 Toyota Sequoia
Maytag mde5500ayw,,,, have interior light and display will light up, but unit will not start???
hello. begin by looking closely at the latch on the door. if it has lint in it clean it thoroughly, vacuum the area and see it it will start up.
if not read on:
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 17, 2009 | Maytag Dryers
Lights staying on
You need to replace the door switch, as it is allowing the interior light to stay on, but also it's keeping the fridge section circulating fan from coming on, and that is what is really causing the interior to heat up.
It's located in the top hinge plate cover and you can test for faulty operation by removing the switch and connecting or disconnecting the wires together to see if your light goes out and the circulating fan starts to run. If so, the switch needs to be replaced.
The part number is #6600JB3007K and costs about $8.00. You can order it from several online sellers or at www.searspartsdirect.com
Here's a diagram of your fridge and the parts list with pricing.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=LFX21971ST&productCategoryId=0161000&brandId=3204&modelName=BOTTOM-MOUNT-REFRIGERATOR&diagramPageId=00001&componentDescription=CASE%20PARTS&documentId=F0902046&backToLink=Return%20to%20Sub%20Components%20list
Hope you found this very helpful and best regards!
Aug 07, 2009 | LG LFX21971ST Stainless Steel Bottom...
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
