Question about Creda Ovens
Creda concept solar plus oven timer
Cannot get timer off auto and cannot set clock , seems as if button stuck when holding it in, oven is not working
  • Anonymous Mar 30, 2014
    Change clock?
  • Creda Master
  • 3,463 Answers
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
100%
Posted on Aug 09, 2012
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Can not reset clock or timer, oven will not work on creda concept solarplus cooker. What is the sequence to press the buttons to reset ?
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Dec 21, 2009 | Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Cant get oven to work after power cut,creda gainsborough 48185
Hold down minute minder + cook period buttons. The + or - buttons will then set time.
Mar 24, 2009 | Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Creda Concept Superglow Stove
I fiddled with the buttons until the oven came on. Dont know which buttons but working now. Thnx
Jul 18, 2008 | Ovens
Ovens Logo
1,565 people viewed this question
Top Creda Ovens Experts
ashburton
William Robinson
William Robinson
Dan Webster
Dan Webster
Are you a Creda Oven Expert? Answer questions, earn points and help others
