Question about ASUS P5LD2-VM Motherboard
S/PDIF IS DISABLED
I am using P5LD2 ASUS MOTHERBOARD and the os is windows 2000.
so far i have been using mic but suddenly the s/pdif is disabled and i am not able to record nor speak thru' mic. The mixer toolbox does not show any controls. Please do help me
  • 106 Answers
Maybe the driver of your sound is corrupt of missing try to reinstall your driver of the sound card
Posted on Feb 13, 2009
S/PDIF port
You probably need to enable the port. This is in the Playback Audio Device control Panel. Connect your cable between the computer and the audio receiver (audio in port). With Windows 7, click on Start > Control Panel. Then go to Hardware and Sound. Click on Manage Audio Devices. Under the Playback tab, look to see what devices are listed. If you do not see a optical audio device, right click on the window and select Show Disabled Devices. Then right click on the Optical Port option and make it the default. (Alternatively, left click and use the drop down menu below.) Click Apply to confirm this.
In Windows 8, use the Charms menu from the Desktop (Windows Key + C). Choose Settings and then the Control Panel. Then follow the above directions.
If you have a different OS, please add a comment with that information. I hope this helps.
Mar 06, 2013 | Computers & Internet
Asus p5k64 ws SPDIF pinouts identified
Asus Support > P5K64 WS > Main Support page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5K64_WS/
Click on the Downloads tab.
(Overview / Specifications / Download / etc )
Click on the blue Down Arrow to the right of the Select OS box.
Click on WinXP
Click on the + sign to the left of - Manual (9) at the bottom of the list.
Scroll the Inside blue scroll bar down, click on the blue - Global -
underneath the E3231 heading.
The port on the top that is to the Right, of the mouse SP/2 port;
is the Coaxial S/PDIF Out port.
Center hole is Positive, outside is Negative. (Ground)
Uses coaxial cable.
"This port connects an external audio output device via a Coaxial S/PDIF cable."
The port below it is the Optical S/PDIF Out port.
"This port connects an external audio output device via an Optical S/PDIF cable"
http://en.wikipedia.org/wiki/Spdif
Regards,
joecoolvette
Dec 29, 2012 | ASUS P5K64 WS Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I am triying to locate S/PDIF out pin for Asus p5lp-le motherboard. Thanks Ghirmai
Do you mean the solder point? The S/ PDIF connector / jack is wired directly to the motherboard and is orange in color. Not quite sure what you're asking. This is a coaxial connector and the solder pin connection would be easily found with a continuity checker, but again you're not too clear in what you're asking. Btw, if this helps, please don't forget to provide a rating. Here are the specs for your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00379616
Jan 13, 2011 | HP Computers & Internet
I bought P7H55-M motherboard. I try to install soundcard (2-cards) E-mu 1212m, but always when I try to install drivers it says that it will stop installation since it doesnt find any hardwareto fit with...
The P7H55-M motherboard has on-board audio and connections to the audio on the rear connections including a S/PDIF connector. If you want to install a soundcard then you should first disable the on-board audio controller in the Bios.
Dec 26, 2010 | ASUS P7H55M PRO (90MIBBB0G0EAY0KZ)...
I have asus p5ld2-vm/s motherboard where can i get a driver for this.. my OS is windows XP Professional?
You can find all the drivers you need in the below link
http://www.driverstock.com/ASUS-P5LD2-VM-driver-download/6-9-10155/index.html
Just be careful because linux drivers are jumbled along with the windows drivers so look carefully.
Jun 26, 2010 | ASUS P5LD2-VM Motherboard
Driver sound card ASUS P5LD2-VM Motherboard for windows 7 ?
u can find ur driver here:
http://support.asus.com/download/download.aspx?model=P5LD2-VM&SLanguage=en-us
select os vista remember version 32 or 64 bit,most probably vista drivers will work on windows7, and then download audio driver.
Mar 29, 2010 | ASUS P5LD2-VM Motherboard
Searching the s/pdif socket on motherboard
hello, i have looked over the schematic,the header should be marked spdif,(small white lettering) right next to or between the pci slots,or near the audio chip. it will be a small black connector. hope this helps,good luck!
Mar 15, 2009 | Computers & Internet
Analog Sound no SPDIF
This may help. The SPDIF not working is differant for each Pc.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51317-1&lc=en&cc=us&dlc=en&product=1832444&os=2093&lang=en
This package contains the driver for the Conexant Audio in the supported notebook models and operating systems. Which I picked Vista for you & your model: Pavilion dv8000t CTO.
Release Date: 2007-05-20 Version: 3.40.0.50 A. Don't feel bad you would be surprised how many pc motherboards & notebooks have this problem. Vista by far is the worst.
There is also a Security Update for HP Software. I'll list the link here as well. (do not know if you did this yet).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01310397&lc=en&cc=us&dlc=en&product=1832444&os=2093&lang=en
The link below is drivers & others for your notebook.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1832444&lang=en
Post back if this did not help & I'll continue to find a better fix!
Understanding a little about S/PDIF & Vista.
Vista does indeed prevent Protected or "Premium" Content (mp3, wma, etc) from being channeled in any manner which would allow the user to create an "un-protected" copy. That is the purpose of the new O/S, to protect DRM at any cost...including customer utility. S/PDIF is considered "unsafe" and is therefore crippled to a great extent in Vista. Additionally, all hardware manufacturers are required to provide ONLY drivers that will inhibit functions such as S/PDIF in the Vista environment. Should Vista find an "unsafe" driver during the mandatory "update" process, the machine will call home and the driver will be disabled.
Feb 05, 2008 | HP Pavilion dv8000t Notebook
ASUS P5LD2-VM Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
