Question about Xerox Phaser 8500/DN Printer
Error Press ?: 07,010.43:20321 Xerox Phaser 8500N
I get this erro message and when I look it up on Xerox website the only thing can tell me is that I must contact tech support.
    President:
  • 2,072 Answers
Yeah they do that on their site, Drives people crazy.
What that code means is your print head is not moving side to side or front to back. There are 2 primary causes. I will cover them for you.
1, Did you have a power failure? Or otherwise shut the machine off improperly. If so, try and power off and power on the machine several times. There is a cleaning blade between the drum and print head that will tack to the print head if the machine power is interrupted. Often times letting it reset and warm up a bit will release the blade from the print head. Reason I ask that is I know there was a lot of wind last night knocking out power all over the country.
Now, if that did not happen, here is what to do.
First there is a print head block. Looking from the front of the machine it is located on the left side. You will have to remove the left side cover, one screw on back, one on front and you have to lift and twist some to release the tabs on the covers. About 2/3rds of the way back, near the bottom of the machine.you will see a stainless steel block, about 1 inch square, That block often times becomes contaminated with spill over ink. It is the result of the machine not sitting level either front to back or side to side. There is a metal clip with a spring , that puts pressure on the print head shaft ot move sideways. If you see a lot of ink build up in that block. Slip that spring off, take some channel lock pliers and remove the print head block. Soak it in some hot water to soften up the ink and thoroughly clean the block and print head shaft. Also remove as much of the excess ink that you can in that print block area. Then when done. LEVEL the machine. Easiest way is to plave a level on the platin glass and make sure its sitting level both front to back and side to side.
Now the print head wiper blade mentioned first. That takes a little more time to get to. You have to remove the right and left side covers, then the ink loader must come out, That is where you place the ink sticks. It is held in with plastic tabs on each side the you release and pull up and out. There are 2 connectors on the ink loader also. Once you get that out, you have access to the print head/drum area. Look between the drum and print head for a pinkish color blade and gently detack it from the print head. Then run the remove light stripes and also run the remove smears mode.
One of those 2 will more than likely resolve that problem, I would say at least 95 percent of the time one of those 2 issues will resolve the problem. There is a clutch that drives the wiper blade that I have seen fail. but try the first 2 and let me know what happens.
Posted on Feb 12, 2009
    Sergeant:
    Champion:
  • 237 Answers
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems
Basically you need to take off the side cover and there are two wheels up top for the wiper. Manually turn that and make sure the wiper is all the way down then you should asee a gear box close to the front on those gears there are holes those holes need to line up it should be one on a black gear and white gear. Also you have to take off the ink loader it just lifts off when the covers are off. Once you have that lifted off make sure the printhead is in a tilted position.And that should take care of your problem
:I have a Xerox Phaser 8500 with the following error: 13.323.47:31989. Any ideas what this is?
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Jan 09, 2011 | Xerox Phaser 8500N Printer
Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Hi there i can no get my Xerox Phaser 8500N to print color what can i do?
Are you using Windows 7? If so, this is a known problem.
The xerox website says to uninstall the printer and reinstall with the correct driver, but this did not work for me.
Apr 20, 2010 | Xerox Phaser 8500/DN Printer
Fault 37, 008.44:197329
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox support website for 37,008:44 error code you should Verify the Printer's power source and isolate the printer.
Oct 26, 2009 | Xerox Phaser 8500N Printer
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
826 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
