Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Light button on fridge door
My beko fridge light button does not turn the light on any more, the bulb is fine but if i touch the button i have to wiggle it till the light stays on. not sure how to get in to fix it...
  • 333 Answers
You can pop this switch out by prying on it with a butter knife under the switch housing. When you remove this switch you can purchase it at any appliance parts store. I hope this helps. Don't forget to rate my answer, thanks.
Posted on Feb 12, 2009
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
My light willnt work in my beko fridge?
The door switch must be faulty.
Apr 24, 2012 | Refrigerators
I have a Model IC6 bottom freezer fridge. the fridge is working but the lights on the upper fridge went out. The freezer lights work and the compressors seem to be operating. I changed the bulbs but they...
there's a light or door switch that could be bad,look around and you'll see a switch that the door hits to turn the lights on and off,i've seen people put the bulbs in cross threaded i remove the bulb thread it in and it works try removing the bulb and put it back in again,also if you unplug the machine and stick your finger into the socket there's a metal tab in there that touches the bulb if that is pushed in to far it won't touch the bulb to work bend that out a little and try it again,all there is is the bulb the socket and the switch and the switches are pretty reliable,they're located on the side or up top where the door closes in on the machine
Nov 08, 2017 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
My kenmore fridge - 4 years old - has developed an intermittant rattle. Stops when the door is open on fridge or freezer. Starts again if you open the door but hold down the light button so it...
That button just turns the interior light on when you open the door and off when you close it. Could a light bulb be slightly unscrewed? Or perhaps the bulb cover is loose?
Dec 27, 2010 | Refrigerators
How to change beko fridge bulb
how do I change the bulb on a beko fridge?
Apr 23, 2008 | Refrigerators
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Dec 12, 2007 | Kenmore 53642 / 53644 Side by Side...
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
430 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
