Question about Diesel DZ7044 Watch
Dz7092 diesel watch, cant change i love u back to diesel mode
Hi there, iv got a problem when setting the tie for the 1st time iv changed the led display after the time to i love u, instead of diesel. anyone any ideas on how to change back, only got set and mode button. many thanks for any help!!!!
the model is dz7092 the red led display,
ps cant find the product name in menu so will use another..
  • Anonymous Mar 31, 2014
    I change the time on my watch when accidentally pushing button B (according to manual - its the top left one) now the watch has turned off completely and I cannot turn it on again. I found out that button B is not usuall used in the setup but I dont think that should lead to self destruction? Does anybody know how I can get it to switch on again?
Have the same problem
Posted on Dec 08, 2009
  • Hans Werner Dec 08, 2009
    have the same problem
How do change the date on my citizen divers watch
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy Instructions
  1. Pull the setting knob (crown) out one "tick" for setting mode.
  2. Set the mode hand to "WT-S."
  3. Pull the crown out one more "tick."
  4. Press the top button on the right side of the watch for the city setting mode.
  5. Press the lower button on the right side to "SET" the city.
  6. Turn the crown to select a different city, which changes the time zone.
  7. Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
Feb 21, 2011 | Citizen Watches
How to do i set up time for DZ7150 diesel watch
put watch in time 1 mode; hold set/el button on bottom left for 2 seconds; use mode button on top right to change between date, hour, minutes, and seconds; use both the right buttons to either go up or down on the different modes; once you have everything set, push the set/el button to save changes
Dec 27, 2010 | Diesel Audio Diesel Watch
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Dec 05, 2010 | Armitron 40/8125BLK Digital Sport Watch
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
May 14, 2009 | Diesel Digital Dz7069 watch
Diesel Digital Watch DZ7069
I finally figured out how to set the time on this watch! Like others the included manual didn't have instructions for this model.
Hold down all four buttons on the watch, this will do a factory reset.
Hold down the top left button, which brings you into the configuration mode.
Pressing the bottom left button will cycle you through all the settings for the time. For each setting, the top right button increments and the bottom right decrements.
When you are done, press the top left again.
Dec 28, 2007 | Diesel Audio Diesel Watch
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 | Watches
User manual for Diesel watch
I was given two different Diesel instruction books with my dz-7069 and neither covers the watch in question. If anyone can tell me how to set the time on it I'd be most grateful.
Aug 15, 2007 | Diesel Audio Diesel Watch
Diesel DZ7044 Watch Logo
533 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
