Question about Nintendo DS Console
Nintendo Ds will not charge!
Some days after changing the upper screen in my ds it stopped charging...when i plug my charger inthere is no lights at all...i have changed the charger as my partner has one and the battery still with no charging...is it the same problem i.e. the fuses or is it more sinister?.. with a charged battery it still boots up and plays games
  • 88 Answers
Yes its a fuse!!
check out ebay uesr ID: ynysmon2007
Posted on Feb 15, 2009
I just got my touchscreen replaced and now my ds wont charge, when I plug it in there is no light or anything and it used to charge before they fixed it
If that DS has been opened by any tech, they are supposed to give warranty.
Bring back that DS to the one that repaired it and tell them that it was charging before you brought it to them, otherwise you could complain that some part have been( hopefully not ) replace mistakenly from another DS.
Hope that helps!
Nov 25, 2011 | Nintendo DS Lite Console
My ds wont charge. How do I fix this?
on the ds, after you connect the charger, the charging light goes on? if not, the problem can be the charger, or charger cable or plug.
if possible, test the charger with another ds, if the charger works, then the problem is ds internal, maybe a fuse or another component.
May 29, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
When The DS Boots the top screen flashes for a second and the whole unit turns off.
You should try charging the DS system if the light is red. Make sure both the outlet you plug the DS into, the charger, and the DS charging port are not damaged. If this does not work, try visiting this website: http://www.nintendo.com/consumer/index.jsp or calling Nintendo Customer Service at 1-800-255-3700.
Hope this helped,
Alex
Mar 17, 2010 | Nintendo DS Lite Console
Doesnt work plug in charger but it doeant charge &libht doesnt come on
I would suggest making sure the outlet you plug the DS into has power. Some outlets do not work unless the room's lights are on. If you have already tried that, I would suggest contacting Nintendo customer service at 1-800-255-3700 or going to http://www.nintendo.com/consumer/index.jsp as it could be a problem with the DS charging outlet or the DS charger itself.
Mar 16, 2010 | Nintendo DS Lite Console
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo ds orange charge light flicker on then off . no power when try to switch on
i also had same problem and gameathlon solved it wow you can buy it here http://www.gameathlon.com/advanced_search_result.php?keywords=Nintendo+ds+battery&x=0&y=0
Jan 23, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
91 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
