Question about Whirlpool LER5636P Electric Dryer
Dryer does not heat
Kenmore model 96284100 - Cleaned all venting ducts, vaccumed instide of dryer and cleaned internal lint trap. Could it be a fuse or heating element and how do I check these?
  • Anonymous Feb 18, 2009
    dryer works the drum spins but no heat
  • jpstuhr
    jpstuhr May 11, 2010
    First to check it is not your ducts, remove the duct and turn on the dryer. If it drys then you still have a blockage in your exhaust vent.
    Problem Solver:
  • 13 Answers
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Posted on Feb 27, 2009
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Kenmore dryer 66812690 over heating
did you clean the inside venting circuit inside the dryer from the blower housing.lint trap etc if the dryers full of lint a clean outside vent system wont help
Oct 25, 2012 | Kenmore Dryers
No heat but dryer runs fine? how can i fix it
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 01, 2011 | Kenmore 600 7965 Dryer
Dryer will not heat up
A clothes dryer can go for years without any problems. We come to rely on our clothes dryer, and we can even begin to take it for granted. Then one day we attempt to use our clothes dryer and it has no heat to it. Now we have entered the world of clothes dryer repair, and it is a world that can get expensive. Before you call out the repairman, try some troubleshooting tips to see if you can get the heat flowing back to your dryer again.
    Lint One of the easiest fixes for a dryer that will not heat up is cleaning out the lint trap and cleaning out the lint from the dryer exhaust. The lint trap should be cleaned out before each usage. Not only does cleaning the lint trap prevent the possibility of a fire, but a lint trap that is filled beyond capacity will cause the dryer to not heat up. If the lint trap is clean, then inspect the exhaust hose and vent next. If the exhaust hose and vent are cluttered up with lint, then the dryer will not generate heat. You can use your hand to clean out the vent, and broom handle to clean out the vent duct in your house. The flexible hose can be detached and cleaned by hand as well. Thermal Fuse A dryer will run on for a very long time, and when the thermal fuse gives up then there will be no more heat. Finding and replacing the thermal fuse is not difficult, but in order to do it you will need the manual for your dryer. Each dryer model is different as far as how to open up the cabinet, and locate the thermal fuse. You may need to purchase the thermal fuse online from the manufacturer, or you may be able to get a universal fuse that fits your dryer from an appliance repair store. Contact the manufacturer of your dryer to see what kind of thermal fuse they recommend. Thermal fuses cannot be repaired, they must be replaced. In most cases it is easy to tell if your thermal fuse needs replacing as you will see the center of it is burned out. Heating Element Another main culprit to a dryer not heating up is the heating element. According to Repair Clinic.com, the heating element is a coil found in the back of the dryer that the dryer uses to create heat. The only way to tell if a heating element is bad is to check the consistency of the current it generates with an ohm meter. If you are unfamiliar with how to do this, you can either replace the heating element and assume it is faulty, or you can have a repair professional test your heating element for you.please comment on these solution by say how helpful.by rate or vote
Jan 10, 2011 | Dryers
Sears Kenmore gas dryer not heating up
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
May 03, 2010 | Dryers
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
Strong odor coming from dryer
Usually when there is a strong heat (burn) smell from the heat element, it is telling you that there is poor air flow. This has nothing to do with the model. It is a blocked or restricted vent line, or an internal blower wheel malfunction or a lint blockage further in the machine that is restricting the air flow. WHEN AIR MOVES CORRECTLY, THE ELEMENT HEATS NORMALLY AND DOES NOT GIVE ANY OVERHEAT ODER.
Oct 11, 2009 | Kenmore 63942 Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
253 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
