Monitor Icon
Description of icon function
Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the
brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of
contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the
horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the
vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to
full screen.
Degauss - This button will
degauss the
CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the
Moire effect, if any.
OSD Controls - If the monitor contains
OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Thanks for your quick answer, The V Size and other controls work, just not the H size, do you still have the same diagnosis?
