Question about Gateway MT3705 Notebook
Need to replace my CD-ROM
Remove CD-ROM
  • 129 Answers
Welcome to Fixya !
Please find the link to the manual for the laptop. It clearly explains the instructions need to remove the cd rom
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Take a moment to rate the solution .
Thanks
Amar
Posted on Feb 12, 2009
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
Laptop is not recognizing the CD rom drive
Remove it and replace the CD ROM Drive. Check whether your Drive is being detected at BIOS. if detected let me know.
Sep 08, 2009 | Computers & Internet
I'd like to replace the cd-rom with a cr-rw. The unit is currently in a dell optiplex sx280 mini desktop
just open cpu cover and remove cd rom from it replaced it with your cd rw then connect power cable and ide cable to motherbord and to cd rw.
Thanks for using fixta.
Please rate solution if it helps.
Jul 27, 2009 | Samsung SN 124 (SN-124) Internal 24x...
Removing faulty cd drive.
if you look right abovce the keyboard you will see a strip that needs to come off ok then you will see 3 screws and one of those screws holds the keyboard in that needs to come off
also after you lift the keyboard from the slot it is in then you will see the cd rom there syhould be a screw on the back of the laptop that is holding the cd rom in place ok just remove the screw and slide out the cdrom ok and just put in the new cd rom and put the screw that holds it in and then replace the keyboard and the screws for that and then replace the strip and you are finished now just power it up and it should recognize the cd rom ok i hope that this is a fixya for you best regards mike
Aug 24, 2008 | Computers & Internet
How to replace CD-ROM in Medion MD40566
Generally what you will need to do is first open the computer case. Then you will see 2 screws on each side of the CD-Rom Drive. You will need to remove these screws. Now you should be able to slide the CD-ROM forward away from the front of the case. Before you completely remove it you will need to remove the cables at the back of the CD-ROM before removing them note the position of them. Now that the CD-ROM is removed bring it to the store and ask the associate for the correct replacement. Once you bring the replacement home installation is reverse of the listed procedure. One thing to not is the position of the Jumper on Slave, Master, or Cable Select. This will be explained on the instructions that come with the new drive. Whatever the jumper setting is on the old drive make sure it is set the same on the new drive. Once this is done turn the computer on and you should be all set. Good luck and keep me posted.
Thanks - Tech101
Jun 24, 2008 | Medion Computers & Internet
CD rom
hi
open your pc case
open screw of rom then remove power and data connection from rom then pull your rom.
then install dvd burner.
power and data code connect.
install burner soft
ok
u have done
Mar 24, 2008 | Dell Dimension 2350 PC Desktop
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Cd rom will not display on monitor
U must set jumper on you'r HDD and CD-ROM, so you have primary and slave IDE controlet, remove HDD and CD-ROM and set HDD jumper master and CD-ROM jumper on slave. If is posilbe use two IDE cables one for HDD and one for CD-ROM. Have luck.
Sep 08, 2007 | Computers & Internet
Gateway MT3705 Notebook Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
