Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
Razer V8 handset ear speaker does not work any fix?
May have gotten wet,other speaker works fine
  • 126 Answers
There is a problem with your jack get it repaired
Posted on Feb 12, 2009
I have a set of Bellsouth walkie talkies and on one, all though I can change the volume settings, I can not get it loud enough to hear unless i put it tight to my ear
Very likely a blown speaker. Those speakers do not stand up to weather well and may have gotten wet. The only solution is replacement. Since you cannot buy a speaker, you would need to buy another radio and use it for parts. Better yet, buy a working radio and use you old one for parts.
Jun 19, 2017 | BellSouth Radio Communications
How do I fix My wireless Headphones (They work in audio cord mode)
I'm assuming they run on battery power and that the batteries have gone dead.
Jun 22, 2015 | Radio Communications
Hi. I am being faced with a recurrent problem. Again and again, the speaker in the flap stops working. so then i have to put on the speaker and talk. I showed the phone to a mechanic, they changed the ear...
the speaker in the flap stops working. so then i have to put on the speaker and talk.I showed the phone to a mechanic, they changed the ear flap with the ear piece but it worked fine for a few phone calls only.Kindly advice.
Jan 24, 2011 | Motorola Mobility A1200
Pan KX-TG3032CS: Handset has dialtone on Speaker, not on Talk. Handset works OK otherwise.
Made phone call on Speaker; worked OK.
(Had to phone the library anyway; good test.)
Took handset apart, determined normal ear speaker was OK.
Disconnected Speaker - never used it anyway.
Switched ear speaker wires to Speaker connection. Soldered connection.
Phone now works fine; just press Speaker rather than Talk.
No parts, no cost, & a working phone. And if there's a problem I can simply reconnect the Speaker & use it that way.
Sep 10, 2009 | Panasonic Lands Phones
I can't hear out of my handset for voice calls. PPlcan hear me fine but it sounds like they are whispering. I was having no problems until tonight. Speaker phone is working fine. What can I do to fix it?
You need to open up your phone and clean both the actual ear speaker and the two small pin holes on the cover with 91% or higher alcohol. If that doesn't solve the problem then need to replace your ear speaker.
Mar 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Ear speaker not working but speaker when turned on works fine
You will need to take the phone to a mobile service center and have them replaced the ear piece
Sep 29, 2008 | Sony Ericsson W200i Cellular Phone
Razr only sound thru speaker
posted by zafaralam on Jul 31, 2008 Report abuse
helo sir
i have one moto v3 there is ear piece problem how to solve this?
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Jul 31, 2008 4%20stars.png
Daelmyth
Rank:guru_s.gif Guru
Rating: 86%, 18 votes
You've either gotten in wet, a small tear in one of the cables, or the speaker itself has gone bad.
I recommend www.wirelesunlimitedinc.com, or www.myspace.com/wirelessunlimited.
They can help with that and they have parts in stock.
Fast turn around and affordable.
Sep 02, 2008 | Motorola Mobility RAZR V3
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
No call volume om samsung e250
This because in your handset there will be 2 speakers
1 is loud speaker and 2 nd one is ear piece speaker....
so the loud speaker is working fine ...
There may be some loose contact in the ear piece speaker or the speaker might have got damaged ...
so if you are good at opening then just open your handset and check if there is any loose contact in the ear piece speaker .. is so fit it correctly ..
or you replace the ear piece speaker with the new one ...
if you are not good at opening then just contact the technician ...
he will do it ...
The ear piece speaker is very cheap so no problem .. just buy the ear piece speaker which is compatible to your handset in the shop if you are doing it by your self ...
the technician might take the service charge for this that s all but the ear piece speaker is too much cheap ..
any doubts reply me
i am always here to assist you
thank you
bye ...
May 14, 2008 | Samsung SGH-E900 Cellular Phone
No sound on my calls on j600
When you make call no body can hear you because there will be mic in your handset it might be in loose contact or the mic is damaged ...
and you cannot hear them because the ear piece speaker is also in loose contact or it is damaged ...
if you are good at opening the handset then just open it and just have a check is there any miscontact in both the mic & the ear piece speaker ...
i think the mic and ear piece speaker are not touching to the circuit board so as it is not in contact you are facing this problem ..
check for the miscontact and solve it ... if they are damaged then replace with the new ones..
while purchasing the new ear piece & mic buy which is compatible to your handset model ..
if you are not good in opening then just visit the technician ...
he will do it ...
The price of the ear piece speaker & the mic are very cheap ...
if you visit the technician then he may take the service charges extra ...
any doubts reply me
thank you
bye ..
May 11, 2008 | Samsung SGH-E900 Cellular Phone
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
