Have you downloaded and installed the latest glide pad drivers from Dell?
Upon starting your laptop I would enter the bios setup screens and navigate the startup screens using Alt+P to find the pointer settings and set your or check that yours is using Glide Pad only, If you so choose to use an external USB travel mouse, this setting must be changed to Serial only.
Once, you download and install the latest drivers for the Glide Pad, and by the way, the Glide Pad on the D600 series is its only weak link in an otherwise best in class laptop.
To access the sensitivity settings for your Glide Pad after installing the new driver or in your case this may be reinstalling (I have to do this way to often) open Mouse within Control Panel and the last Tab is your Glide Pad. Here you can change a lot of the property values for things like sensitivity and double tap scrolling etc. Your mention of the mouse traveling up and to the right in most case is normal for this laptop.
Here is the link for the Glide Pad driver update. If this link has expired,
here is the permanent location. Just click on the download button on this page. Download and move to a unique folder as the file name won't be of help. Move to something like c:\software\Dell\Glide Pad\
Regards,
Worldvet
