By Duke - usenet poster
I'd like to set up a free wi-fi hotspot, and I'd like the hardware to have
an embedded server (i.e. not need to be hooked to a PC to work).
Does anyone know of any wi-fi hardware that has an embedded server that can
be set up to deliver a free wi-fi hotspot?
Best Solution
posted on Aug 01, 2007
maartenw - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Since it will be free, I'm assuming you want to be as cheap as possible?
(I also have a cheap-as-possible "free hotspot".)
How many simultaneous users do you expect?
Any specific reason why it must be embedded?
ZoneCD is a (free and open source) captive portal. It'll run on just about
anything, as long as it has two NIC's and a CDROM drive. No OS is needed.
It is GNU/Linux based, but the OS is on the CDROM. Simply set the BIOS to
boot from CDROM, throw ZoneCD in, and it is running. Throw together a
computer from old parts, build it as small as possible (get creative with
alternative case ideas), and its basically an "embedded" black box anyway.
ZoneCD also uses Dansguard, which can give you the filtering you want.
I just got a Linksys WRT54GS router, which may work itself into my "free
hotspot". I got it more as a new toy to just play around with than anything
else. I'm playing with RADIUS now. They are dirt cheap and highly
customizable. (They run off a GNU/Linux variant, so there are lots of
homebrew stuff out there for it. There is even an embedded captive portal
for it.) Aim for a Version 2, as they seem to work the best with all the
homebrew stuff. Stay away from the V5, as it isn't going to be GNU/Linux
based, and won't be "hackable".
(Serial numbers):
CGN0 = WRT54GS v1.0
CGN1 = WRT54GS v1.0
CGN2 = WRT54GS v2.0
[.Snip N3 tp N5.]
CGN6 = WRT54GS v4.0
ZoneCD:
Dansguard (read more here):
Cheers,
Eric
(Serial numbers):
CGN0 = WRT54GS v1.0
CGN1 = WRT54GS v1.0
CGN2 = WRT54GS v2.0
[.Snip N3 tp N5.]
CGN6 = WRT54GS v4.0
ZoneCD:
Cheers,
Eric
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
pawa - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
If its and embedded server, and there's no PCno problem.
An embedded server seems more streamlined also. Less Windows junk running
in the backgound = more juice for the users.
Solution #3
Gary10 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
$100 to $200 for something that is going to be a relatively dumb box?
Just go to Home Depot and get creative.
Or if it is going to be inside and hidden anyway, go completetly ghetto with
a cardboard box.
(Don't think I've never done that.) :^)
Cheers,
Eric
a cardboard box.
Cheers,
Eric
Solution #4
Ranny - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
[POSTED TO alt.internet.wireless - REPLY ON USENET PLEASE]
In <puw8f.20416$ -0400, "Jim Hubbard" <
Two important considerations when running a hotspot:
1. Prevent patrons from accessing your LAN (wired as well as wireless).
2. Quality of Service to keep patrons from degrading your service.
Small Form Factor (SFF) PC; e.g., Shuttle XPC
Another good product I inadvertently omitted is:
* SonicWALL TZ 150 Wireless
See also the Intel Wireless Hotspot Deployment Guide
Best regards, HELP FOR CINGULAR GSM & SONY ERICSSON PHONES:
John Navas <#>
John Navas <#>
Solution #5
Peter1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I don't want the hassle of a PC just to give a few patrons internet access.
I saw that Axis used to have a hotspot with Linux embedded as a server. You
could simply plug it into your DSL modem and run it. They no longer offer
any hotspot devices.
I'd like something with at least a minimal firewall and possibly even some
parental blocking (to at least make an effort to block porn, etc.).
I may have to use a small pc with a simple wireless router and the
appropriate software after allbut I hope not.
Just in casewhat's the smallest PC you've seen that can run XP?
Thanks for the links!
Solution #6
Bomber - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
In <ebt8f.18257$ -0400, "Jim Hubbard" <
What's the purpose of the server? Depending on your needs:
* D-Link Airspot DSA-3100 Public/Private Hot Spot Gateway
<# * Instant HotSpot
<# * ZyAIR B-4000 Turn-key Hotspot Gateway
John Navas <#>
John Navas <#>
Suggest a new solution for this problem
Post a New problem for D-Link Airspot DSA-3100 Firewall
Email this problem
Email this problem
Can you Help with these Firewalls problems?
Repair Service
Find Firewall Repairman Near You:
