Question about Maytag Neptune MAH5500B Front Load Washer
Unending Heavy Vibration on Spin Cycle - Maytag Neptune
Can anyone tell me how these machines are supposed to balance the load for spin? Mine walks all over the room.
  • ecrms601 Feb 15, 2009
    Did not answer the question of how this design of machine adjusts load balance.
  • 20 Answers
Level the machine, if you are on a wood floor it could be the floors fault, you could try using aanti vibration pads.
Posted on Feb 13, 2009
  • rotorx7tt Feb 15, 2009
    the machine does not adjust load balance per say, when it start spinning it speeds up and slows down wich help distrubute the clothes evenly.
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Why do i get heavy vibration in spin cycle
You need to level your washing machine. If it is not level it will shake. Make sure all of the corners are touching also.
May 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
When i am on spin cycle it stops and has a nf error code! what can i do?
This error code, pops up usually when in the spin cycle, your clothes are out of balance, too heavy of a load, or even at times it can happen with a too light of a load. Just stop or pause your washer and re arranged the items inside,
Jul 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Feb 15, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
310 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
