Question about Rainbow Rainmate Air Purifier
Rainbow Rainmate making a screeching noise!
I run my son's rainmate in his room everynight. Lately it has started making a screeching noise when I first turn it on. Last night it made the screeching noise and then would intermittently stop spinning and start back up. What's wrong with it? Also, I don't know how to remove the spinner to take a look at it and clean it! Help! I can't live without this thing!
    New Friend:
Mine started making a noise. I turned the fan by hand and could feel drag due to dry bushings. Could not get it apart to service the motor, so after removing the fan, I used compressed air to blow all of the dust out of everywhere that I could. Then I figured out where the shaft would line up on the top of the case and carefully drilled aprox 1/4 hole aligned with the shaft. Cleaned out the debris, put a drop of light weight non detergent oil at each bushing on the motor, worked in by rotating the shaft by hand - along with gently pushing and pulling on the shaft while rotating. Re-assembled and seems to be working fine. In my case, the noise was caused by dry bushings. Although I now have a hole in the top, the unit is working. CAUTION - DO NOT DO THIS UNLESS YOU ARE COMFORTABLE WORKING WITH MOTORS.
Posted on Apr 12, 2015
  • Rainbow Expert
  • 324 Answers
It sounds like the motor may be going bad. Not a lot you can do with these machines when the motor goes out. To remove the fan and stem, you twist the stem until in unlocks and can pull it off, next just pull the fan straight down and it will pop off.
If you have had this unit a long time chances are Rainbow will not do anything for you about the unit motor dying. If that is the case we do have a similar item that is a little more budget friendly, looks a little different but works very well.
Green Leaf Air Freshener Humidifier
GoodVac.com
www.goodvac.com
1-800-775-6586
Posted on Oct 17, 2014
Just take it to ur local dealer they will replace it or fix it.
Posted on Feb 26, 2009
How do I clean the Rainmate?
Twist of stem from bottom, if excessive calcium or mineral deposits you can soak in vinegar. Keep hole in stem clean. Do not use harsh chemicals on any rainbow products it will compromise the materials. Vinegar should work.
Feb 03, 2016 | Rainbow Rainmate Air Purifier
Is the rainbow rainmate like a essential oil diffuser?
If the instructions don't say so, I would not do it. Oils can clog air purifiers that are designed for such pruposes.
Jan 17, 2015 | Rainbow Air Purifiers
Rainmate is not working, is there a warranty on it
Try to lubricate the fan bearings/bushings, it should help. If this does not help, check the repair price, or buy a new one
Mar 21, 2013 | Rainbow Rainmate Air Purifier
Rainbow Rainmate Air Purifier Looking for information if the aromas/oils are safe in households with birds! Also, where can one find the MSDS documents for the oils etc.
I'm not sure if this will help or not. I never thought about the aromas/oils possibly being bad for any birds in the house. I ran mine in the small room I use as an office and I have a parakeet in this same room. She didn't have any ill effects from it. So I would suppose it would be okay. That or I have a tough old bird (which she is).
Nov 23, 2010 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Jun 06, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Rainmate question
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful not to place the machine too close to the edge of whatever it's on as it may fall off. The rainmate can be ran 24/7 (mine does :D)as a side note the only upkeep it should need (other than the water of course) is check the little hole on the bottem of the spinner. if that is ever clogged just punch it though with a toothpick.
Air Purifiers Logo
1,002 people viewed this question
Top Rainbow Air Purifiers Experts
jdthefixer
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
