Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My sx200 wont accept compatable ink cartridges
I have even refilled the cartridge it worked the first time but next time it said it was not compatable
    Sergeant:
    Champion:
  • 237 Answers
If you are using refilled ink with epson it can cause the print head to go bad. Epson is very picking when it comes to their ink. I would suggest using there ink
Posted on Feb 12, 2009
Ive changed ink cartridges and still ink light is flashing and not printing
Chances are you are either;
1. using an "expired" ink cartridge. or
2. the Chip on the ink cartridge is erased and will not work.
Many re fillers do not reset the chip after refilling them.
This is Epson's way of saying "I do not like compatible, refilled cartridges...I hope this helps, Happy Holidays...Steve at TakeCharge ReCharge
Oct 22, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Tip
Re-Filling Cartridges, Facts and Fiction
There are many rumors regarding re-filling cartridges, and many people have been put off by the idea due to bad quality, a messy experience or a friend told them not to do it!!
The truth is:
Basically Any HP, Canon, Lexmark or Dell two cartridge printers can be Re-filled with the same results as OEM Cartridges.
Most of the time it is VERY EASY to refill a cartridge, But also depends on a few factors.
Individual Colour Cartridges and Most new Epson Cartridges can be purchased in the AfterMarket world very easily, and the quality of them is very acceptable.
These cartridges are not worth the time to refill versus for the cost of compatibles, although I would recommend Re-Fillable cartridges for high volume users, these have refill plugs and self resetting ink levels. By using these brings the cost per cartridge down to approx $2 per colour
This still leaves all the people who have 2 Cartridges in there printers, and find that even a compatible cartridge is hard to find and still not "cheap",
Provided you have Good quality ink and the correct tools refilling these cartridges CAN BE REFILLED, But there are some tricks to remember.
1. Do not let the cartridge run completely empty, There is a sponge and lower chamber in these type, if the sponge dries and Air gets into the lower chamber, It wont work after a refill. A simple way is to top the cartridges up every weekend, just to be sure.
2. Do not use the cheapest ink you can find. Ink from USA, JAPAN and Australia is the best, Most Other ink is a powder base and has a very poor record. Use inks made from liquid, oil based ingredients. This is the closest ink to OEM standards. Powder Based inks will give a questionable output and probably clog up very quickly.
3. It is Ink, So common sense should dictate to do this over the kitchen sink. I have been Re-Filling cartridges for 6 years and still get ink on my hands!!!
4. Do Not overfill these cartridges or Ink will simply run out of the print head, if the cartridge total capacity is 20ml, use 18ml of ink just to be safe.
5. FOLLOW THE INSTRUCTIONS, Read them before you start, then only if your confident go ahead. If you miss a step the ink can flow when you dont want it! Some cartridges require a air plug or head to be covered before you start, just make sure you READ THE INSTRUCTIONS.
6. If you change cartridges once every 6 months, is it really worth purchasing a kit that does 10 refills???
Keep Posted for more individual instructions to follow. Hewlett Packard refill instructions (two cartridge printers)
I Hope this information is useful, if so please Rate this Tip.Thank You for supporting the FixYa Community
RegardsGM
on Apr 08, 2011 | Office Equipment & Supplies
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Reset ink
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
This means you need to purchase and install genuine printer cartridges.
May 05, 2013 | HEWLETT-PACKARD Hewlett Packard Deskjet...
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
MY EPSON SX200 IS REFUSING TO PRINT WITH MY REPLACEMENT INKS. HOW CAN I GET IT TO ACCEPT THEM ?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 22, 2009 | Epson Office Equipment & Supplies
Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
196 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
