Question about Sony Televison & Video
Need part # A1131319A (Board BR) for a Sony TV model KP-53XBR200.
This part is no longer available from Sony & my actual board isn't repairable.
Thanks in advance for your help,
Robert
    President:
  • Sony Master
  • 1,779 Answers
I've tried all of my suppliers and all come NLA, i'm sorry.. Why do you say yours can't be fixed????
Posted on Feb 13, 2009
I need a D board for a sony projection tv model KP-51WS520. Can I buy this anywhere or does it need repaired? Thanks in advance!
you probably will not find one available and they usually are repaired at com
SONY D BOARD 10 BLINKS REPAIR KIT KP51WS520 , KP57WS520 , KP46WT520
ponent level . but here is a link to the parts to do that with from EBAY
Oct 20, 2014 | Sony Televison & Video
Sony KP-57WS520: Standby light blinking 9 times then repeats
thats caused by failed zero cross diodes on the G board. You can get the G board repaired from www.tvrepairworld.com replacement boards are no longer available for that model.
Aug 04, 2011 | Sony KP-57WS520 57" Rear Projection...
I need part # for Sony KP-51ws500 D board, and
Required D board part number for KP-51WS500 is appended below:
A1300417A... D COMPLETE BOARD
Available in Part Store, click the link for price info.
Thanks.
Jun 04, 2010 | Sony KP-51WS500 51" Rear Projection...
Auto focus not working
Ur tv convergence are dead that why.The convergence board require the 2 STK convergence ICS and some or all it resistors must be change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
May 23, 2010 | Sony KP-53XBR200 53" Rear Projection...
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Aug 21, 2009 | Sony Televison & Video
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Snowy picture in all video sources -Sony Kp53xbr200
I'm working on the same problem. I posted a little about this problem under another question for the 53XBR200. From what I've learned so far with experimenting and studying the schematics is that the problem is with the BR board which is the module that handles upconverting. PIP video goes through the BM board/module. You can pull the BR board out of the set and still have the TV work as long as you keep it in PIP modes. Likewise, you can pull the BR board out, but the set will turn off if you try to go into any PIP mode. The problem with static on every input only remains in full-screen video. As you've noted, all inputs work fine as long as you remain in one of the PIP modes. It does look like the BR board is discontinued. I would like to know how to get a replacement/repair if anyone knows about this. My only hope to get this set functional again is to either force the video to bypass the BR board, or repair the BR board itself. If it's a discrete component on the BR board (capacitor, resistor, transistor) then it might be possible to salvage a repair. If it's one of the upconverting chips, then we might be SOL. I've tried to jump the video signals around the BR board, but this didn't work and the picture looked distorted. I think the problem with this idea is that the video processor might be expecting 480p/960i video and by bypassing the upconverter I'm sending 480i video into the video processor. I'm going pursue this idea some more as it might be the only way to salvage the set from the trash bin.
Dec 31, 2007 | Sony KP-53XBR200 53" Rear Projection...
Kp-53xbr200 SONY video shuts off but sound stays on
Sounds like a bad solder connection. When you lose video, does the on screen display still work, and if so how about your picture in picture? If no OSD or PIP works then you may be loosing your High Voltage to the picture tubes. Some circuit board assemblies are no longer available from Sony for this model so you may be out of luck if the problem is more than a bad connection.
Jan 28, 2007 | Sony KP-53XBR200 53" Rear Projection...
FUZZY (SNOWY) PICTURE
When you say you have tried all the inputs you are not clear if you mean tuner, vcr, dvd, aux, etc. If you are talking about only the cable input it sounds like you have a bad tuner. To obtain picture in picture there are 2 tuners in your set. This would explain why the small picture is ok while the main picture is bad. You should be able to swap the signals (see your ops manual). Try this. If the snow moves the one tuner is bad. If you have put other signals in (besides cable)such as dvd then the problem is in the matrix circuitry where the two signals merge. Either problem should be easy for a good tech to solve and not cost a whole lot.
Jun 01, 2006 | Sony KP-53XBR200 53" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
