Question about Hotpoint Aquarius WMA42 Front Load Washer
Drum not turning
My drum stopped turning, although motor was working fine on inspection. Motor was turning but rubber belt and drum weren't. Any suggestions??
  • pistol_2007 Feb 12, 2009
    Where are/how do you check motor brushes on a hotpoint front load aquarius WMA34?
  • Hotpoint Master
  • 3,463 Answers
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
Maytag Neptune Dryer MDE3000AYW. Replaced pulley and arm (pulley was seized to it), rear drum wheels, front drum glides, belt. Cleaned throughly inside. Worked like a charm for about 6 loads. Went to hit...
I'm guessing that your belt my have been misaligned, which means, no problem!
But, I recently had a machine that had a motor that would not turn, only hummed. I vacuumed the lint, then blew the lint out of the motor with a compressor, and vacuumed again. It still needed a push start to get the motor turning, but it starts on its own, now. So, if you have a lot of lint buildup, it can eventually stop the motor
Mar 06, 2017 | Maytag Dryers
I have a 5 yr old GE Harmony Dryer and it sometimes does not turn the drum. I'd say about 2/3's of the time it operates totally normally, but the other times the drum doesn't turn and you have to open the...
Unfortunately your motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are GE certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on doing it yourself, if you'd like.
The switch your talking about is a centrifugal switch inside the motor. Once the motor turns to a specific RPM, it makes and keeps the motor going until the timer turns it off or the door is opened. But it is the motor itself which starts the spinning. But the motor is not doing it's job so the C switch doesn't come into play.
Best, G
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
The drum on my washing wachine has stopped turning although the motor is still going what could be the problem?
check the drive couple it connects the motor to the transmission have some one hold the machine up feel with your finger the roud rubber disc between the motor and the transmission make sure the machine is unpluged whenu do this you can aslo remove the motor for a better visual inspection of the area part sells for around 14.00 hope this helps
Apr 29, 2010 | Washing Machines
Our gas LG dryer suddenly stopped working. The display works fine, however when turned on, the drum doesn't rotate, and makes a loud humming noise.
check for a motor start capacitor on the side of the drum motor,some use a start cap,if not then either the start relay on the end of the motor where the wires are is bad or the motor bearings are dried out and the motor is locked-up,usually this will trip the circuit breaker though,remove the drum belt and see how easily and how long the motor shaft rotates when spun by hand it should coast to a stop
Feb 16, 2010 | Washing Machines
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
I have a frigidaire model fwl22sa it startted leaking and now it stopped spinning
Same problem here with same make/model. I am not an expert "washing-machine-guru", but I do have a fair level of technical knowledge. Well, when I inspected my washer looking for the problem I found that the rubber hose used to move water from the drum to the extraction water pump is broken. The water escaping the hose is spilling over the electric motor, motor belt, drum brake and water extraction pump. I removed the hose and inspected it looking for the reason it broke. All I can say is that I think that the material (rubber) used is not top quality. Apparently the cause of the failure is age. Maybe the chemicals running thru it may have debilitate the hose to the point of failure. The drum brake is not operating normal, retaining the drum from spinning when it should be. Also the motor belt have stretched a little bit, maybe because of the water spill. If your Frigidaire FWL22SA is leaking water when the drum is being filled you better refrain from using and inspect the hose. I buy the hose (original spare/repair part) for only $3.99 and installed myself. That is far cheaper vs buying a new washer. Good luck.
Aug 18, 2009 | Frigidaire Washing Machines
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
Drum doesnt turn... motor fine.
From your description I would suspect a broken belt although I am unfamiliar with your model. Once the belt [which transfers drive from the motor to the drum] breaks, it would'nt matter how well the motor runs, it can't turn the drum.
Hope this helps!
Oct 08, 2008 | Bosch Axxis WTA 4107 Electric Dryer
Drive belt and noises.
your drum shaft is broken this is making the pulley wobble causing the belt to come off and it will also explain the noise. This is a very expensive job sometimes requiring the complete tub to be changed might be time for a new machine
Jul 30, 2007 | Bosch Classixx WVF 2402 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
301 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
