Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and Paykel ecosmartWashing Machine Agitator flap broke off
I need to replace the agitator as one of the 3 bottom flaps broke off. Unless I hear otherwise, I will continue to use the washing achine with the broken flap since it does not spin very fast and I doubt that it will cause any harm, but I'd like feedback on this anyway. Also, how can I get a replacement agitator and is it easy to install one myself?
Thank you.
Bill Goss
98-766-4164
qualitysystem@comcast.net
  • 145 Answers
Hi Bill...
It takes all of 5 minutes (if that) to change the agitator. You pop off the fabric softener dispenser on the top of the agitator, then reach down inside and undo the plastic wingnut that secures the agitator down and then simply lift if off.
As for issues with using it with broken fins, you could end up with some clothes damage, especially to delicate items, if you continue to use it that way.
You can get the part here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=229
Posted on Feb 14, 2009
  • camplim Oct 10, 2010
    The flaps broke off my agitator ages ago and I have been washing just the same but without such good results. If I knew it was so simple I would have replaced it ages ago. Thanks so much.
  • boris Sep 16, 2013
    i say just smooth and round the edges off with a dremel got tried of replaceing mine
I had the same issue occur with my FP washer. It's ashame that these part have to wear out in such a short period of time because the they are built in a flimsy manner.
Anyway, the repair is very simple and takes only a few minutes.
Posted on Jul 21, 2010
I've had the same issue with my FP washer, obviously a design flaw. I haven't tried fixing it or replacing it yet, but I likely will as the edges are jagged and sharp. Thanks for the help
Posted on Jan 22, 2014
I got tried of replacing mine and just smooth and rounded the ruff edges off where the flap broke off with a dremel .
Posted on Sep 16, 2013
Can't secure agitator wingnut on 7.5kg Fisher & Paykel top loader.
try rotating the agitator some and see if it drops into place on the shaft .
Oct 26, 2015 | Fisher and Paykel Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Model GW712av wont agitate
Will the bowl turn with no water in it,
If not turning the bearings are seized and rusted.
A bearing and seal kit is needed for your machine.
Aug 15, 2012 | Fisher and Paykel Washing Machines
Something is stuck underneath the agitator in m Fisher & Paykal Aquasmart. How do I remove the agitator?
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Jul 08, 2011 | Fisher and Paykel WL37T26D Top Load Washer
How do u replace the agitator on a fisher & paykel clothes washer gwl15 ?
Disconnect power then lift the lid open. Pry the dispenser assembly off the agitator top then remove the agitator bolt by turning it counterclockwise. Once the bolt is off, lift the agitator then install the new agitator in place. Secure it with the agitator bolt then put the dispenser assembly back into position. Lifting the basket helps budge the agitator and remove it more easily.
Mar 02, 2011 | Fisher Paykel EcoSmart GWL15
REPLACING THE AGITATOR
unscrew the plastic nut down the centre and then pull the agitator up and off
Jun 28, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel top loader washing machine self cleaning mode
wonder if it means the agitator is full of lint? to remove agitator, put your hand/arm down center of agitator and unscrew the white plastic knob. Agitator lifts off. Mine is always clogged with lint and crud.
Oct 10, 2008 | Fisher Paykel EcoSmart GWL15
Cleaning washing machine
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
Jun 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
3,724 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
