Question about Maytag Neptune MDG5500AW Gas Dryer
Heating not staying on
When we go to dry a load of clothes, The dryer will heat up and about 10 min. later the dryer will be cold. Everything else seems to work properly just the heat is not staying on.Maytag Neptune  gas dryer 9 yrs. old takes at least 2 hours to dry a small load. Yesterday repairman replaced coil kits($186). Those little things looked fine to me but he said the copper was broken inside of them.  Dryer even worse now.....3 hrs and not dry at all.  Were we ripped off? Should we just put the old ones back in and look for another root problem. Our model number is actually MDG4000AWQ but could not find in your list. Thanks ,  Susie
  • Maytag Master
  • 19,396 Answers
Test the control panel and the wiring harness to the coils
Posted on Feb 12, 2009
  • Ginko
    Ginko Feb 12, 2009
    If the appliance was heating from time to time , the problem were not the coils (heating elements).
    The most likely is that you have either a problem with the wiring harness to the coils, that with vibration is losing contact , also a bad control board or termostat can give you similar problems , but the wiring is the most likely.
    The technician should have measured elements for continuity before replacing. If it did so, then you can know if elements are good or bads.
    Call back the technician , and tell him that the problem was not fixed. More than a rip off this looks like in inaccurate diagnosis/testing after repair. Call the guy back to finish the job.
  • Ginko
    Ginko Feb 12, 2009
Aquarius. Why doesn't it heat and dry clothes?
An internal fuse may have opened or the heating element may have failed
Nov 01, 2015 | AEG T58840 Dryer Electric
Our LG dryer doesn't dry clothes very well. We usually have to run the dryer 2 or 3 times to dry our clothes. I've checked the lint filter, hose and vent. Everything is clear.
if you have checked vent all the way out to termination point and sure that it is clear and not obstructed with damp lint then i would say you possible have a bad thermostat on the heater... this regulates how often and how long the dryer heating element runs and stays off.it has a open temperature and a shut down temperature... i would suggest replacement of that first... it is located on the heating element of unit... it is a round disk shape like bi-metal with 2 wires attached to it...
good luck to you....
Feb 13, 2011 | Dryers
My dryer stops drying after 10 min. All the lights flash on the right hand side. I've tried different drying settings and different amounts of clothing. Nothing works. What's wrong?
My dryer does the same thing. Additionally, it is not heating what so ever. Clothes are cool and damp, and heating vents at back of dryer are cold to the touch.
May 11, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer wont dry my clothes
Your heating element is not working. The element could be burnt out or the high temperature switch is bad.
May 29, 2009 | Dryers
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Kenmore Seris 90 Front load dryer
I agree with you that the possible culprit is the thermal cut off sensor. The extreme heating could be caused by a malfunctioning thermostat or heating element.
Mar 07, 2008 | Dryers
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
147 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
