Question about Biostar M7VIZ Motherboard
I am hearing two beeps when i start my cpu,and problem with grap
When i start my pc i here two beeps and if the ethernet drivers are there then it is not talking vedio drivers.and wise versa.then what is the problem.
pentium D processor,1 GB ram,and i am having IDE hard disk and dvd rom
    President:
  • 1,179 Answers
The 2 beep code is telling you there is one of 2 problems. Problem 1 could be bad or improperly seated RAM; or 2. A bad or improperly seated video card. Since you say it's not taking the video driver then my best advice would be to try reseating the video card, if that does not fix it then replace the video card. Hope this helps & please take a moment to rate my solution. Thanks.
Posted on Feb 13, 2009
I have a used HP/Compaq dc5800. I reinstalled win xp pro to clean out HD. When finished I noticed the computer did not recognized the ethernet card, sound card and graphics which are all integrated. i...
You would need to look at the BIOS manufacturers site for the beep code and it's meaning. You can also pull all the hardware out, memory HDD, CD/DVD and boot if you no longer get the error, power down and add one component back and boot. Repeat until you get the beep code again and you will know what the problem part is.
Oct 08, 2012 | HP Compaq DC5800 Small Form Factor PC...
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
When i turn the power on, 3 beeps play, the fan runs and the power light comes on, but nothing else
Hearing ONE beep is normal, and a signal that the computer hardware is OK.
Hearing THREE beeps is a signal that something is wrong:
* burnt-out CPU,
* one of the fans is not spinning (clogged?) or spinning too slowly (about to seize-up),
* one of the RAM chips is defective
* the video-card is not working
If there is more than one RAM stick, remove all but one stick, and start it up, to see if it starts.
Check that the fans are spinning freely.
Dec 14, 2010 | Gateway GM5260 PC Desktop
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
I have a 2003 or 2004 emachine that I am trying to start up to get my old info from, however I have two issues. 1. no signal from monitor and I have checked all cables. 2. when I turn on the CPU, there is...
one of your ports is not working or your ram is not seated. thus beeping. On mine once I seated my ram the beeping stopped and I could continue.. If you say there is no signal to the monitor maybe the video card is bad. do you have a spare to throw in and try. Then hook it to the internet, either with an ethernet or wireless adapter and have it find your driver and maybe that will work.
Mar 17, 2010 | E-Machines eMachines Desktop PC
Hp compaq d350 sff; xp os it won't start up but the two lights on the front blink. what gives?
This is a sign of a "frozen" system. Did you hear any "beep" when the system starts? If you heard a beep, then your video is ok.
Now, you need to open the CPU Casing and remove your RAM modules. Now, connect the PC again even without the RAM. Your CPU must start beeping which indicates that it detected NO RAM.
Now, put in the RAM modules back. It is better if you can swap their positions if your have 2 RAM modules or transfer it to other slot if you only have 1 RAM.
Then start your PC. It should work fine now.
Feb 02, 2010 | Computers & Internet
Desk top won't post
you have to listen carefully for the type of beeps is it long or short and how many beep, coz in computer maintenance all this has meanings.
Jun 01, 2009 | Computers & Internet
On powering on'the screen remains black and the ethernet plug is flickering. no sound from the hard drive
the hard drive could have failed..Try a hard start to see if it will react. Do you get any beeps?? a warning beep or beeps may indicate a hard drive failure. Try to get into C-Mode set up. click alt/cntrl/del as you turn on the set.or alt/cntrl F10. Hard drive failures can happen if ther is to much written to the drive or just a plain 'Crash'.
Oct 14, 2008 | HP Computers & Internet
PCVRS620G won't turn on
i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
Feb 07, 2008 | Sony PCV-RS620G PC Desktop
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
Biostar M7VIZ Motherboard Logo
296 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
