Question about Watches
I want to build a watch using an eta movement,i have seen on ebay tag cases ,and many movaments, this is to be my first build,i have only basic watch knowlege but it has always been a dream to do this .is there a site were i can get help, or a guide or step by step instruction many thanks david davidmarshall 1@yahoo.com
  • 495 Answers
  • Watches Master
  • 19,396 Answers
Let me know what kinfd of movement you want to us.
Posted on Feb 12, 2009
  • 679 Answers
I can provide u  with a link where u can find help
  • rockfixya
    rockfixya Feb 12, 2009
    Here is the link>>
    http://forums.watchuseek.com/archive/ind...
    let me know if this is helpful.
  • rockfixya
    here is another link which will help you to build a watch using ETA movement>>
    http://www.masterwatchmaker.net/watchreg...
Tag heuer wk111a-0 instructions
This watch has ETA movement.
The instruction for the watches with the same movement is in
http://www.old-omegas.com/1665en.html
Dec 03, 2010 | Tag Heuer 2000 Classic Multigraph...
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
Dating a cartier pasha watch
no because your watch has a eta movement made by the swatch company cartier buy the movement from eta then decorate it and sign the rota with there logo the movement could be 2yrs old before cartier get the watch to retail...ie. sat in the shop window. only cartier could tell you when your watch was manufactured..the srial numbers you provide identify what the movement is using cartiers own code to identify the movement and one is for the the model ie. seatimer..
Mar 26, 2010 | Cartier New Pasha Seatimer Steel W31080M7...
Need a new watch movement
I am not sure which Vincente model you have but I can tell you that the movements for those are Swiss made. That may not seem like much but there's not a lot of info on them.
Chances are it's an ETA movement and if not there's an ETA movement that should fit it. ETA is one of the top Swiss movement makers around. You will find their movements in more watch over $1500 then I care to mention. You should be able to get a movement for around $150 plus installation. You will need to go to a watch repair shop so find a good one.
Hope this helps.
Jan 10, 2010 | Vicence Watches
I am about to buy tag heuer link calibre 36 limited edition 1996/2000 and is got these numbers at the base cn111b.ba0337 and a signature and a japanese name is this watch original? thanks
Fake Tags are common! The only surefire way to tell if its real is by the movement! They use Swiss ETA movements. Fakes use Japanese movements! If you are purchasing this watch online...well good luck! If you can take it to a watch repair company then I would suggest that before you buy so they can open the case back and see what kind of movement is in it! A real Tag will cost upwards of $1500 plus and I would think a Limited Edition would be even more!
Jan 09, 2010 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
How does the swiss eta g10.211 quartz chronograph work
I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
All Quartz movements are pretty much the same operational wise. They can vary greatly in materials used for construction and number of jewels.
At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator to vibrate a tuning fork. This vibration is a is brought down by micro processors to a meaningful number then converted into mechanical energy trough the movement and hands.
In the case of a chronograph it means more internal gears and jewels.
Although this is a good movement it is the low side of middle of the road.
The G10.211 is an analog display of hours and measured time. These include hours, minutes and a small jumping second as 6 o'clock. Mechanical date and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and 'SPLIT" functions. Operated by 2 push buttons.
It has 6 jewels.
If you want to know something more specific please just ask.
Hope this helps.
Dec 31, 2009 | Bulova Watch
I have a Breitling Chronomat! I have to adjust the time everyday when I get up in the morning. For some reason it stops working in the middle of the night. I thought that since these watches are automatic,...
They should not stop during the night. You are right.
Several things could be happening with your watch. Either the mainspring is weak, broken or is slipping too much.
This is a repair that will require a qualified watchmaker to perform. Not just any watchmaker can service this watch. they need to have been trained how to service an ETA 7750 movement. Preferably a watchmaker that was trained by ETA.
The movement in your watch (ETA 7750) is a very complicated movement. It has over 450 parts and there are certain parts that require special handling.
Unfortunately the way the movement is made there is no way to repair the mainspring problem without completely disassembling the movement. So this requires a complete service of the movement.
I know this is probably not what you wanted to hear but I hope it helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Breitling Chronomat Evolution 756...
What type of swiss quartz movement is in a tag heuer aquaracer waf1010 ba0822?
ETA or F0 movements are usually tags number 1 choice of movements.
ETA G10.711
Jul 13, 2009 | Tag Heuer Watches
I have an Oris BC3 which was never a great time keeper; gaining or losing 5-10 seconds per day. Recently, it started to gain at an alarming rate and I took it to be cleaned and regulated at a watch...
Take your watch back to the watchmaker and ask to regulate the watch again. After a decent repair watch shouldn't loose or gain that much and if properly regulated and tested can keep good time. ORIS is using the same Swiss made ETA movements as Tag Heuer, Ebel, Montblanc, Tissot, Maurice Lacroix etc. These are very good mechanical movements and can be adjusted to allmost perfect timekeeping.
Dec 22, 2008 | Watches
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Dec 04, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
