Question about HP Business InkJet 2800 Printer
Firmware error Were can i found a firmware update
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What is the firmware version that you have now?
  • HP Master
  • 19,396 Answers
Posted on Feb 12, 2009
Wen I connect the network cable, 49.4C02 error code appear o HP Laserjet P4014dn, pls help!
Easiest way to update firmware on this model will be to download the easy firmware update, connect a computer direct with a usb cable and then run the firmware update after the computer finishes installing the printer.
Aug 14, 2014 | HP LaserJet Office Equipment & Supplies
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
How can error 98.01.01 be solved
When exactly did you get the error message 98.01.01? Was it while you was trying to do a firmware update? I found a forum support page regarding this error but so far it remains unresolved on many websites. I checked all of the LaserJet's error codes and, like in the forum link, it appears this is related to a bad firmware update or faulty connection during a firmware. I have heard of people just repeatedly trying the firmware update until it goes through. In fact, there is a firmware update for this printer.
To get to the firmware update, go towww.hp.com/supportand type in your product name under Software and Download and press enter. Next, you will have to select which printer you have (m551n, m551dn, or m551xh). Once you select that, it will take you to a Business Support Page and the firmware updates are located on the left hand side under Setup, Install, and Configure and then in the middle of the page you will see "Firmware Download and Install." I will need to know a bit more information before I can help you with any of those steps, however.
First of all, how is the printer connected to the computer? What is the Operating System and System Type of the computer (Windows 7 64 bit, Windows XP, Mac Version X.X, etc)? Are you able to print or do anything else with this printer? Answer those questions if you need any more help.16x16_smiley-happy.gif
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 14, 2014 | HP LaserJet 600 M602DN Laser Printer - M
What should i do to Stop initialization error
Check the paper paths are clear and reseat the toner cartridge. I assume this is not the result of a firmware update?
Try a reset, I found instructions for a hardware reset on another forum:
1. Power down
2. Press <right> and <cancel> buttons together
3. Power up during pressing these Buttons
this should clear the error, if the problem is due to a firmware update here's a link to an hp forum
M1212nf fails to initialize after firmware update HP Support Forum...
May 08, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
I cannot update my firmware. when i try to do it and error message prompts on my screen saying the software is modified and cannot be updated
seems like your firmware got corrupted, use sony ericsson software updater (download from SE website) to update your firmware else you need to re install new firmware with help of professionals.
please vote me if found helpful.
Aug 01, 2011 | Sony Ericsson K850i Mobile Phone
Will read blank dvds but will not read prerecorded dvds or burn onto blank dvds. I have upgraded from Windows Vista to Windows 7, I keep getting a firmware error.
download this program
http://www.freecodecs.net/fc/ImgBurn_2.5.5.0.zip
install it and run it
its a disc copying software but the reason i am saying to download it is that it will update your firmware for you
click write file to disc, then click on tools then move to drive then go to the last option on the new menu that says Check for Firmware Updates, click ok then click on the numbers listed below version( pick the one that is the latest) this will download the firmware file. extract the files from the downloaded zip and open the installer allow it to finish then click finish or exit. then restart your pc. Now try your dvd
Mar 07, 2011 | Computers & Internet
COBY MP3, MP610-4G, NOT WORKING. SCREEN READS, "FILE SYS ERR"
Updating the firmware should be done for this type of error: For PDF instruction you could download this by doing below: 1. Go to http://cobyusa.com 2. In the right side of the page type MP610 and hit Enter 3. Click MP610 Firmware Update for File Sys Error 4.Unzip file and read the procedure
If you have no time to download pls perform the ff: File Sys Error This is a system firmware update. This update will fix the "File Sys Error" message and restore the MP3 player back to the factory settings. The firmware update file can be downloaded at www.cobyusa.com. Important This procedure will delete all contents on the MP3 player. Please make sure that you back up all your documents before proceeding with the firmware update. To backup all contents on the MP3 player, simply connect the MP3 player to your computer. The MP3 player will be listed under "MY Computer "as a removable disk. Double-Click on the removable disk and copy and paste all the folders/files on your desktop.
Firmware Update Procedure Do not have any USB Devices connected to the computer including the mp3 player. - Download the firmware file from our web site. The file will automatically run itself once it is done downloading. The below screen will appear. Do the Following: 1- Connect the MP3 player to your computer. It will show up in the number one box in the firmware update software.The windows explorer bar will also pop up when you connect the mp3 player to the computer. Simply close the explorer bar. 2- Once the MP3 player shows up on the number one box, click on the "Firmware Feature" icon to start the firmware update. 3- After the firmware update has been completed, you will receive a check mark in the firmware number one box. Disconnect the mp3 player from the computer. Close the firmware update software. Turn the MP3 player on. If the mp3 player reads Coby, then the firmware update is successful. Use Windows Media Player to transfer your music files in the mp3 player. This will restore the Artist, Albums..etc selections in the Music menu. If you have a problem with this device, please read the troubleshooting guide on the user manual or visit us on the web at www.cobyusa.com for Frequently Asked Questions (FAQs). If these resources do not resolve the problem, please contact Technical Support. Phone: 800-727-3592 Weekdays 8:00AM-9:00PM EST Weekends 9:00AM-5:30PM EST Weekdays 8:00AM-5:30PM EST
Feb 18, 2011 | Audio Players & Recorders
Screenplay plus partition not found ok so whenever i turn on my screenplay plus it just gets a partition not found error
1. download firmware update
2. create partition and format to ntfs
3. update firmware, when finish connect to tv it will still say partition not found just wait a while
for installation to begin. after installation finish everything will be working
Nov 24, 2010 | Iomega ScreenPlay Plus 34499 Digital Media...
Error 49.4C02
This error relates to application file types not working, such as PDF, Word etc.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=130&prodTypeId=18972&prodSeriesId=415204
Download the HP Firmware update for the specific printer and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00267158
I found that Windows XP & Windows 7 work fine after doing the firmware update, which was released in June 2010. However, Windows Vista continues to have issues, despite the firmware update.
Nov 17, 2010 | HP LaserJet M4345 MultiFunction Printer
Error Message
This just sounds to me like you have a slight error. You may need to update your firmware/drivers or formatting.
One of those solutions should fix your problem.
To update your firmware you will need to visit your mp3 players manufacture, I have found your firmware all you will need to do is visit this link and download the firmware/drivers -
http://www.sandisk.com/driverdownload/index.asp
Once your on the website choose your mp3 player ect.. then click download.
If that doesn't do the trick my final solution is to format your mp3 player then update the firmware/drivers.
To format a basic way follow these steps. First click on "Start" - then go to "My Computer" - then look for your mp3 player if the name hasn't been customized it will come under the name of "Removable Disk" - once you've found it right-click on it then click on "Format".
Once you've formatted then do the first solution surgested. which was install the firmware/drivers. Once you've done that upload music back on to your mp3 player then see if the problems be fixed.
Good luck. Hope my solutions were helpful.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
HP Business InkJet 2800 Printer Logo
2,116 people viewed this question
Ben Johnson
