Question about HP PSC 1510 All-In-One InkJet Printer
Photo copy and scan
Just recently when i scan or photo copy the paper comes out with what looks like a long barcode all the way down one side of the paper. i checked the glass and cleaned it. i have no idear what it can be?
  • matty_s62 Feb 13, 2009
    STILL THE SAME AFTER REINSTALLING THE DRIVERS.
    Sergeant:
    Champion:
  • 246 Answers
First try to reinstall the printer divers
Posted on Feb 13, 2009
How do I replace the cord on this scanner? (IT3800) 1 screw has been removed but scanner does not seem to want to come apart
If you look at the side towards the bottom, you'll see a small hole. Get a paper clip and push the tab of the cable down and pull the cable out. Contact us if you need further assistance.
Tech Support Barcoding Technical Support
Feb 03, 2016 | HHP Hand Held Products IT3800LR-12 Barcode...
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Ajbennett@gvec.netI have a 5250 kodak printer and when I copy something the paper comes out gray with black lines down the side. It does print. Why is the paper colored and have lines on it?
You are possible loading the paper in up-side-down. Try loading the paper flipped over. A lot of kodak photo paper have bar-codes printed on one side for the printer to scan and verify you are using the proper paper for the printing job you assigned to it.
Apr 08, 2011 | Cameras
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
Help needed on ricoh ft 4015 copier
1-you need to determine if the two are part of the same problem
If the jamming occured first with no signs of copy quality issues then, it depends on where it's jamming. Locate the 1st jammed paper, the one that is furthest towards the exit. this stops all other paper after it. for example if there are papers in the fuser -by the drum and coming out if the tray the problem is most likely in the fuser area. Are the papers being crumbled? or just stop at that location?
2-the half dark copies could be a couple of things
a) the seperation unit is going bad and making the copies rise up against the drum
b)does the lamp that come on to scan the original stay on the whole lenght of the paper or does it turn off half way down the page? if yes the cable that connects to the lamp is probably broken and not making contact at the half way point as it is scanning.
Sep 17, 2008 | Office Equipment & Supplies
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
HP PSC 1510 All-In-One InkJet Printer Logo
Ben Johnson
