Question about Tomtom GO 720 GPS Receiver
Tomtom GO 720 won't connect to tomtom home
So i just bought this and can't access the tomtom through tomtom home. i've uninstalled, restarted, reinstalled then plugged in the tomtom and in tomtom home - it says that 'there is no compatible tomtom device connected to the computer'. it also says 'please connect your tomtom device using a usb cable and turn it on.'
this has been done. i've tried all various combinations (and have also reset it). the weirdest thing is; when i click 'my device' in tomtom home - the tomtom acts as though it is being accessed, but it doesn't show up in tomtom home. when i plug it in via any of the usb's, it'll show in my computer as a removable device, and also the autorun function works. so it's all connected but seems to be a problem with tomtom home.
thanks so much for anyone that can help. it sucks to buy this and straight away have it not do what it's supposed to do.
  • 4 more comments
  • Blackadder42 Feb 19, 2009
    My tomtom go is doing the exact same thing.
    Getting boring now.
    Have tryed the reset, tryed the format of memory card, fully charged, all 4 usb ports tryed, uninstalled software and reinstalled.
    Sent email to tomtom support now.
  • Anonymous Feb 27, 2009
    My TomTom 540 Live has stopped connecting to my MacPro. Used to connect fine.
  • cdcferreira Mar 02, 2009
    Suddenly my TomTom is no longer recognized by Windows as an external device (HD). TomTom goes through the steps after asking me whether to connect to the computer or not (which means it recognizes the cable is connected to a computer) but the connection is never fully completed.
    Any help would be appreciated.
  • Anonymous Mar 05, 2009
    Tom tom will not connect to computer,
  • Anonymous Mar 16, 2009
    same here, wont sync. computer doesnt see it, doesnt ask to connect to computer, tried multiple usb ports.
    did anyone get a resolution to this?
  • duanyca Apr 09, 2009
    SAME
Hold the reset button in for 15 seconds located on the botton of the tomtom,plug in the usb then the tom tom and turn on this should slove your problem
Posted on May 17, 2009
  • 4 Answers
Agree with dave10031. If you have an expansion card in with any software update stored on it, then your GO720 may not talk to your cell phone (blue tooth becomes inactive), nor will it be recognised by the computer when you connect it via USB. Solution: remove the damned expansion card, then just either use the 720 as normal, or connect in the usual manner to your computer to update software, maps, etc. Only ever update mapping software to the INTERNAL MEMORY - never to the expansion card, if fitted.
Posted on Nov 23, 2009
If you have a memory card in your TomTom - take it out before you sync!
Then bigo jingos - your PC will see the tomtom as a tomtom not some sort of mass storage device that it has no USB driver to run.
Simples!
Posted on May 23, 2009
  • 515 Answers
TomTom Go 720 map activation
No Maps Found usually means the Application on your internal memory is not the latest one, or the map did not download correctly.
Make sure when you select internal memory when updating your device on home, that you update the application as well.
V8351 should be the latest application for your device.
Oct 04, 2009 | Tomtom GO 720 GPS Receiver
My computer will not acknowledge my tomtom go 720 is plugged in to usb connector power light is on in charging cradle but computer says not connected
I had the same problem. I tried uninstalling software and re-installing it. That did not help. I reset my TomTom Go 720 with the reset button on the bottom of the unit. The computer then recognized my TomTom.
Aug 30, 2009 | Tomtom GO 720 GPS Receiver
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
TomTom 930 GO will not connect to TomTom Home
Try to use another computer or another usb port for it. You could also try different usb cable that fit´s into tomtom´s connector.
Jul 29, 2009 | Tomtom GO 720 GPS Receiver
I can't start my tomtom 720 in Windows vista
WHEN CONNECTED TO YOR CPU . YOU TOMTOM SCREEN WILL ADK CONNECT TO COMPUTER NO or -YES. TA YES ON YOUR TOM TOM SCREEN.
Apr 03, 2009 | Tomtom GO 720 GPS
I Have no CD-ROM for the Tomtom GO 720 I just purched.
The cd that normally comes with your TomTom is to load TomTom Home onto your computer, and maybe the owners manual, both of which you can download for free from TomTom.
Mar 16, 2009 | Tomtom GO 720 GPS
Tomtom 720
Make sure you download the lates Home software - probably availalble at www.tomtom.com
After you say yes to conect to the computer and the screen goes black - jut re-press the on button on the GPS while it is still connected to the computer - it will then work. I also try to open the GPS as an external drive which forces the identification of files while TomTom home is working.
Nov 03, 2008 | Tomtom GO 700 GPS Receiver
Cannot connect to computer
when i conegt the gps no seid nathing no i need a software i think so
Sep 04, 2008 | Tomtom GO 720 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
7,859 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
