Question about Microsoft EXCEL 2004 for Mac
Unable to read the file
I have created an excel file in Excel 2003 STD Edition. The size of the file is about 10 MB. It has no links to other excel files. It is showing "Unable to read the file". Can u solve this problem ?
  • Gerald Russell
    Gerald Russell May 11, 2010
    are you trying to read it with the same version that you created it with?
    10 MB is pretty big - how many rows?
  • 189 Answers
Probably the file is corrupted.
search in google if there is any program to cure the file or do another think, get this file to another pc/laptop and try if it opens there.
Posted on Mar 10, 2009
  • s4singapore Mar 10, 2009
    probably the file is corrupted.
How to repair damage excel file
Use Excel Repair Toolbox designed to restore data from corrupted .XLS files. MS Office .XLS file repair software can fix many error.
For more: https://www.xlsrepairtoolbox.com/
Jul 14, 2015 | Microsoft Excel for PC
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Reduce the size of excel file
or
Apr 22, 2013 | Microsoft Office Computers & Internet
Hello! my problem is, the microsoft excel 2003 edition of may pc doesnt work,what would i do? where can i download a microsoft excel 2003 for free? thank so much!
Hey
Microsoft Excel 2003 isn't free.
You can use Open Office as a free alternative to Excel 2003
here is the link where u can take Open Office
http://download.openoffice.org/
The Excel alternative is called Calc and Writer is alternative for Word
Be sure to save the files as name.xls so they will be available for Excel users to
Sep 13, 2011 | Computers & Internet
Dear specialists, I've faced with error with BO Report: The excel file is updating every 15 minutes, but since yesterday BO creates corrupted excel file. Status of appropriate schedule:...
Excel unable to read file is able to resolve Excel repair worksheets, fonts, formulas, cells, columns, rows and etc. Software gives back excel data crashed by any reasons: viruses, incorrect actions anti-virus software, hard drive failures. Tool has the compatibility with Windows 98 and higher. Its interface doesn't require special skills and is simple for novices.
Jun 03, 2011 | Business Objects BusinessObjects...
"unable to read file" message when opening an Excel workbook.
I was sent an excel file (.xls). friends on mac and pc can both open it.
i am on mac and keep getting unable to read error. it must be something with my mac. what could it be? nobody else has this problem.
Jan 03, 2009 | Microsoft EXCEL 2004 for Mac
Do i can customize my paper size in MS Excel 2003
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Dec 18, 2008 | Epson FX 1170 Matrix Printer
Office 2003 Standard edition compatible w/ Small Business edition
Where were you saving the old Excel files to: c:\my documents for example. Is your new Excel saving or retrieving documents from the same location? If not, it will look like the old files are gone, when Excel is simply looking in the wrong place.
An installation won't wipe out data files--they're in two different locations. If you do a global wildcard search (*.xls) you will probably find them.
Dec 09, 2008 | Microsoft Office 2003 Small Business...
Microsoft works 7.0
From the Microsoft Office 2003 Web site:
Excel 2000 or later versions cannot directly open files created in Microsoft Works version 3.0 or later. To open a Works file in Excel, first open it in Works and use the Save As command to convert it to one of the file formats listed below. Then close the Works file and open the converted version in Excel.
  • Works for Windows 2.0/Works for DOS SS
  • Excel SS
  • Lotus 1-2-3
To open a Microsoft Works database file in Excel, first save the file in Microsoft Works as a dBASE file, and then open the dBASE file in Excel.
Feb 11, 2008 | Computers & Internet
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Microsoft EXCEL 2004 for Mac Logo
126 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
