Question about Hotpoint Ultima WF860 Front Load Washer
Wt960p hotpoint wot does f-05 mean
  • Hotpoint Master
  • 3,463 Answers
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Let me know if you require any firther info.
Pleas rate my solution.
Thanks.
Posted on Feb 12, 2009
  • Barry Coates
    Barry Coates Feb 12, 2009
    Highly unlikely pump faulty, I have been repairing these washers for some time, and never had to replace a pump on this range of washers.
  • 1,031 Answers
Press PAUSE/CANCEL twice to clear the display.
Check the drain hose and make sure it is not plugged or kinked.Check the electrical connections at the pump and make sure the pump is running.Check the drain pump filter for foreign objects.If the above does not correct the problem, replace the pump.
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
CODE F-05 NOT EMPTYING
check the pump for a blockage....
cheers
Apr 07, 2015 | Hotpoint Ultima WT960P Washer Front...
Where is the pressure switch on a wt960 hotpoint washer
usually located in the panel on the left said has a clear plastic tube going into it
Aug 01, 2014 | Hotpoint Ultima WT960P Washer Front...
Wot does code F-05 mean on a hotpoint ultima washer mean?
It means water level switch jammed on full.
You need to check and clean pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose
Reassemble and water test..
Feb 15, 2011 | Hotpoint Ultima WF860 Front Load Washer
My washer is flashing f-05 wot dose this mean
go onto google ask what is F 05 it will give the answer
Aug 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Repair manual for hotpoint wt960p
The error code does not mean that the pressure switch is faulty, it is indicating a fault that affects the function of the switch.
The problem is actually a blockage in the pump or pump filter.
To rectify the problem, do the following.
Remove large black hose on bottom of drum.
Remove hose onto pump, and check for blockage or obstruction hers as well.
This should solve the problem
Please leave feedback for my solution.
Thankyou.
Jan 19, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima WT960P has developed a very severe vibration under load on fast spin - how can I fix this Tom
hi there....most probable cause is a main bearing failuer..or a cracked spider unit at rear of inner drum.......both scenearios require a comleted strip down of the wash tub
regards Sir Galahad
Aug 16, 2009 | Hotpoint Ariston AW125 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
259 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
